Anyone know how to de-pin the alt plug?
Old Apr 14, 2010 | 06:24 AM
Bird333's Avatar
Default Anyone know how to de-pin the alt plug?
This is on a 96 Accord. Anyone know how to do it? I can't seem to figure it out.
Old Apr 14, 2010 | 07:19 AM
RICKSAUTOMOTIVE's Avatar
Default Re: Anyone know how to de-pin the alt plug?
usually a good electrical tool set has special tools for doing this. i have a good craftsman set that has been great so far. they cost about 75-100 bucks. i cant remember exactly how much it was but try that set. it has little picks that can get in the plugs and press the little lock-pin in the connector and then you simply pull the wire of the pin out that you are releasing
Old Apr 14, 2010 | 11:52 AM
Bird333's Avatar
I think I have something that will work, but I can't see where the locking tab(s) is for these pins.
Old Apr 14, 2010 | 12:01 PM
it could have a different locking tab. my electrical tool set has a bunch of **** in there that IDK what they would be for. possibly other types of locking tabs. honestly though, i have never taken this plug apart. why are you taking it apart?
Old Apr 14, 2010 | 12:24 PM
TheMuffinMan's Avatar
He knows where you live!
I can't remember what it looks like off the top of my head. But for circular female/male ends you buy a small hollow metal cylinder tool that fits over it and squeezes the pins back away from the plastic. I know Newegg sells them for computer power supplies, I used these on some of my Accord's plugs (ECU namely)
Old Apr 14, 2010 | 07:27 PM
Bird333's Avatar
You got a link?
Old Apr 15, 2010 | 01:17 AM
HondaPartsHero's Avatar
Technical Hero
just curious are you trying to convert from OBD1 to OBD2? If so check out this pic:
Old Apr 15, 2010 | 03:47 AM
Bird333's Avatar
Wish I had seen this 2 weeks ago https://honda-tech.com/forums/honda-accord-1990-2002-2/96-alternator-regulator-fit-inside-00-a-2753816/. But no, I am really trying to figure out how to de-pin the plug.
Old Apr 15, 2010 | 04:19 AM
http://www.chilledpc.co.uk/shop/prod...roducts_id=582
Example of a set right there
Old Apr 15, 2010 | 03:36 PM
h0p3l355dork's Avatar
Have you tried just using a small flat head screwdriver and just jimmying it a bit? It shouldn't take much
Old Apr 16, 2010 | 05:44 AM
Bird333's Avatar
Yes. I can't tell where it is clipped at. The only thing I can think is that there are two circular parts to the pin that may need to be compressed at the same time to get it out.
si_racer
Oct 15, 2012 11:18 AM
h22lude317
Jan 18, 2009 09:59 AM
Ek9_6
Oct 24, 2004 10:10 PM
ApexiChild
Mar 1, 2004 04:14 AM
GSR-REX
Jan 10, 2003 07:40 AM
