obd1 obd2 harness
Old Apr 14, 2010 | 03:31 AM
novaslean's Avatar
Default obd1 obd2 harness
I have a 93si (p28 ecu obd1) I bought a motor stamped b16a2 (obd2). Besides chipping the ecu do I have to change any wiring or get any conversion harnesses?
Old Apr 14, 2010 | 05:14 AM
azandford's Avatar
Default Re: obd1 obd2 harness
you need the obd2 to obd1 converison harness
Old Apr 14, 2010 | 07:55 AM
CivicSpoon's Avatar
The plugs for the injectors, distributor, and alternator are different for the OBD2 engines. So you'll either have to use OBD1 B-series parts (your stock injectors will work fine), or you'll have to change the wiring for those 3 things, or you can use OBD2 parts and get an OBD2 Integra engine harness.
Nope. An OBD2 to OBD1 conversion harness is for the ECU plugs only. Since novaslean has an OBD1 car, and is planning on using an OBD1 ECU, there's no need for a conversion harness.
Old Apr 14, 2010 | 09:23 AM
novaslean's Avatar
thx ... yeah, I thought the conversion harness was for the ecu, have been getting some mixed info so I have been reposting to try to be more specific and straighten it out. thx again.
mitchell_2kSiR
May 23, 2008 01:49 PM
roachsboosted16
Nov 16, 2007 10:11 PM
NOman0608
Jul 26, 2007 10:28 AM
1.8L_allmotormilitia
May 2, 2007 08:28 PM
