FS: '95 Prelude Si
Old Apr 13, 2010 | 05:34 PM
GaRn's Avatar
Default FS: '95 Prelude Si
Desc: '95 Prelude Si
Excellent shape, body has a handful of parking lot dings, really have to look at the right angle in the right light to find them, no body damage, smooth running, all common prelude problems have been taken care of as listed below. 149,500 miles, daily driving so that may go up. Power steering/brakes/windows/door locks/keyless entry, moonroof (no leaks), tilt, ac, etc..
-NGK spark plug wires / plugs
-CSF 2 row radiator
-Hayden 12" electric fan
-Redline Water Wetter
-Golden Eagle Cam Plug
-Honda balance shaft retainer TSB
-replaced camshaft seals at timing belt change
-repalced balance shaft seals at timing belt change
-replaced front main seal at timing belt change
-replaced water pump at timing belt change
-replaced timing belt 25k miles ago
-replaced starter with OEM rebuild 15k miles ago
-replaced distributor with OEM rebuild 20k miles ago
-adjusted valve lash 35k miles ago
-just bled clutch line
-NEW battery
-Innovative motor mounts
-H&R Sport Springs
-KYB AGX adjustable shocks
-Neuspeed strut bar
-Tanabe Sustec Pro tie bar
-Rota Flights 15x6.5 (12.5 lbs)
-BFG G-Force Sports
-JDM VTEC calipers
-Brembo rotors
-Axxis Ultimate brake pads
-Muteki open ended lugs
-Valvoline SuperSyn brake fluid (just did a full bleed)
-OEM fogs (original to the car, pretty rare)
-Skunk2 shift ****
-ITR shift boot
-Image Dynamics CTX6 coaxials
-Alpine 98XX (can't remember, was top of the line $500 Alpine in 2003 or so)
-Will throw in Adire Shiva 12" in Adire spec box for extra $200, no amp, sold.
The bad:
-Some rattles and vibrations, mostly when idling due to solid motor mounts, worse when cold out. I can put the stock motor mounts in if wanted.
-4 small cig burns on the seats, in bottom pictures, very very small, from previous owner
-ABS light is on (common Prelude problem). Can disconnect the ABS control unit to turn the light off, or replace ABS modulator.
Price: $4,950 (Not interested in any trades, cash only)
Contact: PM me please!
Pics:
Old Apr 14, 2010 | 02:48 PM
GaRn's Avatar
Default Re: FS: '95 Prelude Si
Old Apr 15, 2010 | 05:25 PM
GaRn's Avatar
top
Old Apr 17, 2010 | 06:37 AM
GaRn's Avatar
up, more interior pictures added.
Old May 2, 2010 | 03:57 PM
GaRn's Avatar
up, one of the best condition 4th gens you will find!
mosheikh
Nov 21, 2009 09:35 AM
GaRn
Nov 4, 2009 07:34 AM
dELfONiK
Mar 12, 2006 12:39 PM
rossockr
Feb 20, 2003 03:29 PM
quikrpm'z
Feb 19, 2003 03:14 AM
