wtf no spark
I did an obd1 convertion had spark and fuel but the dam thing didnt turn on so i put everything back all converted to obd0 and now i have no spark....tried diff coil,diff igniter and nothing it used to work before i checked for power at the coil and i have power i check for voltage at the igniter i have voltage at the black and yellow wire and at the white and blue wire i dont know what else to check ....
I'm not sure if your car has one, but check to see if you have an ignition manifold. it would be by the coil, or distributor. maybe even attached to the disrtibutor, Same thing has happened to me before only, not in a honda. haha. But I changed it and everything worked fine.
Idk, this may have been no help.
1992blueGSR
Oct 24, 2008 06:11 PM
philkehn
28
May 26, 2006 09:40 PM
tRex99
Dec 30, 2004 11:00 AM
