b20vtec died wont start
my b20b/type-r started sputtering and died when i started it
its getting fire all the way to the plugs, its gettin fuel, the injectors are firing, and timing is perfect. The red light on my S100 is staying on like it should, ran a compression test and was 180 across the board. already changed dizzys still firing, but no start. its obd-1 s100 p28. changed ecus also but nothing. Any ideas fellas motor has been runnin in a different car for a while, jus gettin the motor into a 98 hatch its been runnin for about 2weeks jus in the drivway. please help
positive bro i pulled the rail with the injectors and shot fuel in the air. and pulled the plugs and theyre sparking good. i cranked it that morning let it idle it ran perfect, havent got the exhaust hooked up yet so i dont drive it. cranked it up that night it started sputtering, hit the gas it wouldnt rev then it died, it cranked back up and died, wont crank at all now. its not hitting at all sounds like theres no fuel or spark one, but i have both, i also drained and added new fuel im stumped. its wired perfect i do harnesses. i got no check engine light. please help
Rubenjames25
13
Mar 6, 2014 11:55 PM
ORguy
10
Mar 22, 2011 05:25 PM
Wrona
Feb 6, 2011 02:56 PM
