wiring issue/ignition issue.
ok so I was having some problems lately with car not wanting to start and thought it was my alt but got it tested and it was fine. Batttery is fully charged and good. Then it didnt want to start at all. The starter turns and fuel pump whines. Tried ether to see if it would start and still doesnt. Tried the dizzy and was geting no spark. Replaced the dizzy and still have no spark. Ignition switch is brand new as well. Tested all fuses and theyre working as well. Put new grounds on the right side of the engine to the body and put a ground on the tranny just to be sure. and still the engine doesnt turn over. it really tries to and the RPM gauge even jumps to 1k and flops back down to zero. Any ideas?
I have an internal coil. Its a jdm h22a in a 96 si. But that also gave me the idea to check the jumper wire on the external coil harness. Ill check all that.
scobaru
11
Oct 24, 2016 06:44 PM
