HELP! What goes here!? Pic inside!
Old Apr 13, 2010 | 09:58 AM
sketchaholic's Avatar
Icon3 HELP! What goes here!? Pic inside!
I am peicing together a OBD1 B18B and it's ready to be put in but I have one plug that is open and I'm not sure what goes here. It is the plug just next to the oil pressure sending unit to the left of the oil filter ****. Thanks
Old Apr 13, 2010 | 10:28 AM
tuan_turbo_dc4's Avatar
Default Re: HELP! What goes here!? Pic inside!
That plug on the right side of the oil filter location is suppose to be on the left side also. The person before you modified the left side for a catch can setup.
Old Apr 13, 2010 | 02:39 PM
94-integra-ls's Avatar
^^^ is correct you will need to replace it will the same as on the right or run some sort of catch can set up or install some kind of plug it looks like the hole is tapped
Old Apr 14, 2010 | 12:26 AM
could I just plug it with a bolt or would that be harmful to the motor?
It is a threaded hole.
Old Apr 14, 2010 | 01:25 AM
racebum's Avatar
catch cans are a smart idea. since you're already tapped, set one up. the pcv system just sucks for high performance use and especially boost.
Unphzd
May 9, 2011 08:01 PM
vannak_5415
Oct 6, 2008 05:34 PM
thabao
Jan 31, 2008 07:03 AM
94dxt
Apr 21, 2003 03:37 PM
ee-gsr
Jul 13, 2002 01:48 PM
