Too much fuel, bogging, slow revs , glowing red exaust mani..Stumped.
hey i got a 91 integra , it seems to be having fuel issues - when i start the car up it idles extreamly rough , and revs up really slow even with the throttle wide open , and i could smell gas like crazy so i looked under the car and the cat coming off the header flange was beat red ...glowing , i had switched ecu's eary that week to a chipped pr4 and took it for a drive , it worked good , then i had parked it when it ran outta gas . about 2 days after i pumped it up with surpreme and fired it up and it was running like complete **** ....the car was through'n a code 13 on the ecu , i switched it back to the stock ecu ...no codes but still running like **** and turning the exaust glowing red .....this is stressing me out and i need help
i took the fuel rail off agian yesterday and checked out the injectors , 2 of them are not pumping fuel into the combustion chamber so it think that is my issue with the fuel but i tried switching them around to see if some were bad but its still not getting gas in the same cylinders , heating up like a bastard glowing the cat red.... but why would they not be spraying ? engine harness? another faulty ecu ? plugs? **The spark is good , and i think the timing may be off a slight amount. the car is running like a **** bag and is burning rich on 2 cylinders..... ****..........and i also Changed the fuel filter today and that did not do **** ...
it might be gettin a small amount of fuel in those injectors because when i'll hold it at 2 grand the engine will kind of spit and jump the revs up to 3, 4 k then sputters down to 2 , the car wont idle , it will die and ill be having the throttle allmost half way to the floor when its being held at 2 k , it seems to be running extreamly rich and when i punh it to the floor it will rev up really slow .....it's pissing me off...it's getting nice out and i wana paint it and start cruzin bad guys **** its driving me nuts ....i loose sleep at night cuz im wondering wtf it could be ...lol
SETI20
Nov 23, 2004 01:17 PM
