power port dead?
Haven't yet? Isn't that on a shared fuse? I assumed something else would also be out if that were the case.
Broke my foot a week ago so it's kinda hard to get under there.
It should be fuse 27 (10A), labeled as cigarette lighter acc socket. If the fuse is good then check for power at the socket (yellow with green tracer). Then check for ground (black). If everything checks out then replace the socket. If you are lacking power or a ground then start looking for opens in the wiring.
get a test light and hook it up to your door frame and then stick it in the acc. socket and see if it lights up. if so then should be gravy often times crappy phone chargers and stuff just go out. i'd try a couple different accessories to see if its maybe what your plugging into it as well.....or if you want to take it off then.....
pretty much just remove the center console and driver lower dash trim and there is a screw or two aboce the socket, and open the glove box and one in the top left corner. total should be about 10-12 screws
I'm fairly certain the charger port is out. This is my sister's car and I know my phone charger works.
Thanks for the tips, will definitely tear into this soon.
Not yet. Between work, school, networking meetings, commuting, my gf, and a broken foot, it's kinda low on the priority list, lol.
lol get it fixed or it will be broken when u need it. This happened to me and i regretted it. I had my phone die on me and my car charger didnt work because the plug was broken and then my car broke down. I had a wall charger only and I had to get out of the car, lock it and go walk around until I found somewhere that had a plug.
Then I walked to a mcdonalds and waited there until my phone had enough power to turn on to call my friends. The story is so long that I am going to stop here. But basically worst day ever.
green eyed bandit
Nov 16, 2011 06:14 AM
wildzx
10
Jan 8, 2010 07:28 PM
lx130
Audio / Security / Video
Aug 14, 2006 09:32 AM
