6th Gen Accord Progress Rear Sway Bar Question
Hey guys, quick question.
http://progressauto.com/products/sfI.../productID/425
Is this the correct model for a 6th gen accord sedan?
I've looked around the the TL / TL-S bars are the correct ones so I'm guessing this TL bar should fit too?
TL;DR?
Part #: 62.0110
Car: v6 accord sedan
I asked the guys at Progress but they didn't know if it'd fit. Let me know what you guys have experienced.
TL;DR?
Part #: 62.0110
People commonly use CL-S/TL-S and newer TL sway bars on their Accords. That bar will fit without problems. However, at 24mm thick, that is probably going to be one hell of a stiff bar. I'd really consider upgrading the front sway to go with that, so as to not have a car biased towards oversteer.
Yes any 04 tl sway bar will work for any 98-02 sedans and coupes and yes even the progress sway bar from an 04 tl will fit fine and you do not have to upgrade the front sway bar, you can but you don't have too
sounds good, looking to order that soon. ANy suggestions on endlinks? i've heard you should replace those too and am debating between OEM and Moog as I've heard good things.. ideas anyone?
good info. im planning on getting this sway as well. i cant find the neuspeed race version which is supposedly 25mm, but this will do nicely.
i hope this is correct for my 2001 v6 accord application.
correct me if my understand is wrong.
progress technology
04-08 Acura TL Rear anti-roll bar
Part #: 62.0110
will need to manually adjust some sort of exhaust hanger to make it fit without rubbing.
progress technology
Part #: 62.0110
