zc on zex..
zc on zex!!
installing zex this weekend..
ill be running a 55 shot wit zex plugs,
when i plan to run the n2o i will retard the dizzy 2 degrees,bump up the fpr to 50 psi(more gas= more power and less chance of BBOOMM), and a msd window switch wit 3k and 6600 rpm pills(to prevent hitting rev limit..i tend to do it on accident)
so does this look like a pretty safe/fool proof setup..
also when i run it for the first time i want to check to see if im running lean or not..how soon do i need to check the plugs after i run it?? no a/f guages..
Guest
Posts: n/a
zc on zex!!
when i plan to run the n2o i will retard the dizzy 2 degrees, not needed unless your advanced. just put it back to 0 (stock)
yes and zex sucks if you have stock fuel, you get about a 35 shot
and a msd window switch wit 3k and 6600 rpm pills(to prevent hitting rev limit..i tend to do it on accident) why you driving like a momo then?
yes however nothing is 100% safe do a compression test and leak down test to see if you motor is up to it
also when i run it for the first time i want to check to see if im running lean or not..how soon do i need to check the plugs after i run it?? no a/f guages.. buy one, rich plugs have carbon deposits all over them, lean they're friggn white. you prolly wont lean out at all, after all this is a zex kit where it only sprays if there's fuel to do so
[Modified by TorteX, 4:23 PM 9/10/2002]
ImprtTunr
Jan 17, 2002 01:24 AM
