Spring rate and ride quality
I have crappy lowering springs on my car....sprint springs that are a 2.5 drop
I'm wondering what kind of springs to replace these with, I heard that a better spring rate will give you a better ride (not as bumpy all the time)
am I wrong? What is a good affordable spring>? I was thinking eibach or maybe neuspeed lowering springs
neuspeed race springs are good, a cople of people i know have them they like them alot . I can get you neuspeed shipped for 180 dollars. you wont be dissapointed..
Replacing just the springs is only solving 50% of your problem...
Why not get stiffer struts too?
KYB/AGX are really cheap and they are 4-way adjustable.
I know that I'll need new struts to really make a difference....just wanted to know what kinda lowering springs I should get
It could also be caused by inadequate shocks/struts. If the spring rates are to stiff for the shock to dampen then you can have a bumpy ride. However, riding on a
2 1/2" drop the bumpstops are probably the cause.
its not a hard bumping...but on a bumpy road is like no stop bouncing...I assume its because the sprint springs are crap and also the car is lowerd on stock struts....would just getting new struts be better than getting springs and struts?
for a smooth ride make sure they re progressvie springs..i have the eibach prokit and its about 15 % stiffer than stock standing..the get alot stiffer when push d ull get about 1 1/2 drop up front and 1 1/3 in the back
m R g S r
Suspension & Brakes
Dec 26, 2005 08:35 PM
