first post, need help. Clifford 50.5 on a Pilot
I installed a 50.5 on my pilot, went with a simple setup, arm, disarm, and remote start, no auxilaries. I got the arm and disarm working. the remote start is not working properly, I press the start button twice, the starter cranks and sounds like the engine is running, then it shuts off maybe 2-3 seconds. tries to restart two more times with the same outcome. I tried to get it to "learn" the tach by starting it with the key and holding the button until the light comes on, but the light never comes on. I tried switching the jumper on the module for the tach threshold and tried learning the tach again but it still never light up. Any ideas? any help would be appreciated.
I tapped into the tach test point, I havent checked it with a meter yet but, i am using the single blue wire that was loctated under the airbox, lower side of the driver fender. Is there another tach point i can use? Thats the only one I have been able to find info on. Thanks.
Bklyn TSi
Audio / Security / Video
Jan 1, 2002 06:32 PM
