RPM is Erratic and Fluctuates when driving Hard, EG Civic with B18C1 swap
Old Apr 11, 2010 | 01:06 PM
eghatch510's Avatar
Icon2 RPM is Erratic and Fluctuates when driving Hard, EG Civic with B18C1 swap
To make a long story short, I finally got most of the bugs fixed with my swap, but the RPM fluctuates and it is all over the place when I drive the car hard. It makes it hard to know when I am redlining.
Normal driving it works fine. I finally got my knock sensor and oil pressure sensor wired up and thats when it started doing that. When I had those connections off (oil pres. & knock sens.), RPM did not fluctuate but I did have a check engine (because of the knock sens).
Any Ideas?
Old Apr 11, 2010 | 02:15 PM
Naiyasin's Avatar
Default Re: RPM is Erratic and Fluctuates when driving Hard, EG Civic with B18C1 swap
How does the RPM guage fluctuate? Does it drop and kick back on rapidly while accelerating?
Old Apr 11, 2010 | 02:49 PM
eghatch510's Avatar
It goes up and down +/- 2000rpm. It's not consistant. When driving normal it's fine
Old Apr 11, 2010 | 04:23 PM
tonyhatchetman's Avatar
iacv,.clean or replace ,... air in coolant system,....bleed the system,......... what temp thermostat did you put in??
Old Apr 11, 2010 | 05:29 PM
eghatch510's Avatar
It is the stock thermo. What's wierd though, it only started happening when I got the plugs for the knock and oil press sensor wired up. I cleaned out the throttle body but it only happens near redline.
Old Apr 13, 2010 | 04:54 PM
eghatch510's Avatar
Alright finally fixed the problem! I sprayed a **** load of carb cleaner in the throttle body and it seems to be running fine. Thanks!
Ecky
May 21, 2011 01:57 PM
EGricky
Sep 21, 2009 06:52 AM
integramic
Sep 15, 2004 05:52 AM
d16y8coupe
Nov 22, 2002 02:09 PM
