n00b question....which exhausts DONT have the "bottlenecks"??
Old Sep 10, 2002 | 06:30 AM
RTW DC2R's Avatar
Default n00b question....which exhausts DONT have the "bottlenecks"??
There are 10,000 threads on exhausts, but dont really answer my question. I need to get an exhaust to help my REBUILT NA motor exhale better, but I dont want one that has bottlenecks. If Im not mistaken, most axle backs like the Spoom need to be fixed by cutting off the flange and putting on a new one. And then some B pipes need the same alteration. I dont want to go through all that. I was thinking about the Mugen Twin Loop, but I dont know if its got those "bottlenecks" or not. I do like that it seems to be one of the more quiet exhausts out there. Any others out there that I should look for? Quiet is a plus, but if it has a silencer for long trips, then that will do. Thanks for the help.
Ryan, who doesnt know how to cut and weld exhaust piping
Old Sep 10, 2002 | 06:35 AM
JPP's Avatar
JPP
Default Re: n00b question....which exhausts DONT have the "bottlenecks"?? (Type Rizzle Fo' Shizzle)
What are the modifications to your car?
SMSP has a good design.
Kakimoto R 70 mm (but you need the proper lenght cat converter)
Old Sep 10, 2002 | 06:51 AM
RTW DC2R's Avatar
Default Re: n00b question....which exhausts DONT have the "bottlenecks"?? (JPP)
Its a full NA setup, basically everything but rods. I was looking into SMSP but dont really know much about their setups. Id rather get a full cat back but will check out other options. I dont want to get too off track on this thread, but does SMSP have a full cat back? or just B pipes?
Old Sep 10, 2002 | 06:54 AM
Willard's Avatar
cat back = bling!... ED and George both have them...
I would but that $$$ is better spent on payments.
Old Sep 10, 2002 | 06:57 AM
JPP's Avatar
JPP
I beleive he design and makes full cat back systems.
xjohnx's Avatar
SMSP is the way to go if you've got the $. their header and exhaust are top notch. wish i had the loot for one
Old Sep 10, 2002 | 06:59 AM
juniordc2's Avatar
my sheepdog n1 exhaust doesn't have any.. its 60mm all the way from the cat to the exhaust. no bottlenecks. jdm rules! this exhaust was made for the JDM ITR, but was modified to fit my GSR.
Old Sep 10, 2002 | 07:06 AM
RTW DC2R's Avatar
Default Re: n00b question....which exhausts DONT have the "bottlenecks"?? (dc2gsr94)
Im not that worried about getting the absolute best exhaust, I dont want the most expensive one I can find just for the name. I know from reading the boards that SMSP is top notch, but apparently a full set up from them is not cheap. If I can find a full set up, even it it might make a few hp less than another brand but is hundreds cheaper, then thats the one I want. I will sacrafice 2 or 3 hp to save a few hundred beans.
Old Sep 10, 2002 | 08:59 AM
CPR's Avatar
CPR
Go custom.
Old Sep 10, 2002 | 09:13 AM
Mike M's Avatar
Founding Member
Default Re: n00b question....which exhausts DONT have the "bottlenecks"?? (CPR)
95% of people Worried about "Bottle Necks" Shouldn't waste their time worrying.
Old Sep 10, 2002 | 09:18 AM
RTW DC2R's Avatar
Default Re: n00b question....which exhausts DONT have the "bottlenecks"?? (Mike M.)
why?
as of right now, my entire exhaust is a bottleneck. I have enough money sunk into my motor and think I have reason enough to worry. Or are you just saying that the typical bottlenecks dont really hamper performance?
[Modified by Type Rizzle Fo' Shizzle, 1:20 PM 9/10/2002]
Old Sep 10, 2002 | 10:44 AM
Hooch'n's Avatar
Willard: Payments on car or BEER ( )?
Old Sep 10, 2002 | 11:45 AM
Mike M's Avatar
Founding Member
I'm saying that the Miniscule bottlenecks that most people worry about aren't going to hamper performance. The only time removing them is going to play a large role is if the car is either Forced Induction or Highly Modified. Most of the people out there worrying about bottleknecks don't have any reason to worry but they heard this and that on the internet so it must all be true..
If you Engine is fully built with all the bells and whistles then go Custom and get something that is a straight as can be and Under Axle Exhaust. If not just get an exhaust that is large enough and leave it at that.
Old Sep 10, 2002 | 02:46 PM
Art Vandeleigh's Avatar
i agree 100%. for most people anway. you can have pre-bent aluminized tube put together for pretty cheap. talk to thermal exhaust and ask for jon. he is a great guy and they might be able to cut you a deal if you also get one of there cans. good luck
Old Sep 10, 2002 | 05:07 PM
SMSP's Avatar
FYI,
The larger diameter axle backs that are designed to bolt up to the stock B pipe or B pipes that bolt to the stock axle back tend to have bottlenecks so they can work with the OEM donut. If you are running a USDM header (2" collector) you can get a 2-1/4" cat and a 60mm cat back system that is 60mm at the B pipe flange and you'll be OK. If you are running a 2-1/2" cat the only commercially available system that has a 2-1/2" ID at the B pipe flange is the Kakimoto R which is like 70mm OD. Otherwise you need to go with a custom system to ensure a 2-1/2" ID at the B pipe flange.
Stock ITR B pipe and a 2-1/2" cat used with JDM headers.
The stock ITR B pipe bottleneck.
This was the bottleneck on Jason's car with his 60mm Tanabe RM cat back when using a 2-1/2" cat and a Toda header.
The above mod netted 4 whp through out VTEC.
Historyg
Aug 27, 2008 06:01 PM
BlueRex1020
Jul 17, 2006 10:08 PM
sleevedgsr
Dec 5, 2004 10:05 AM
ck01R
Sep 24, 2002 07:55 PM
Ludester
Jul 13, 2002 03:37 PM
