GSR Swap issue-Injectors? HELP!!
Hey guys, I need some help. I'm in the middle of a GSR swap in my 93 Hatch, the motor is in but wont start. Its an OBD1 B18C1, i am getting spark, and it seem 2 want 2 start, but im pretty sure the Injectors arnt firing. Ive tried 3 different ECU's, swapped the main relay, the fuel pump primes and I am getting gas in the fuel rail. Any suggestions?
First thing I'd do is make sure all your grounds are connected and don't have any corrosion or paint on anything.
I believe you can take a long handle screwdriver and place the tip on the injector and place the handle to your ear, and use that like a stethoscope to listen for a sort of a clicking sound. (Be careful not to touch any live wires). If it is the injectors, just about any Civic/Integra injecters are the same 240cc type that you need.
littleprophet13
Feb 15, 2010 07:47 PM
