jackson racing sced my element tuning help
original post https://honda-tech.com/forums/honda-minivans-crossovers-trucks-80/jackson-racing-sc-my-element-tuning-issues-2758120/
so i finally finished me install on my 08 element sc. my element is an auto awd. the car runs. but my emanage isn't really doing the trick. i was wondering if anyone makes a more user friendly piggy back then emanage. i just cant get it tuned correctly my afrs are way to low. i go to fix my afrs and something else goes wrong. need some help
thanks guys
thanks guys
I just thought that since i had an emanage i would use it but i was using it on a civic with a turbo and it was easy to tune but this element is giving me problems. i will look into the aem fic too thanks
didnt read the original post, but is everything set up correctly on the emanage? You should have control of the tune. OR is this the emanage that when you tune it, the factory ecu corrects over time? Is this emanage Ultimate or like a "blue box emanage?"
Basically what I am asking is, did you set up the emanage so that the factory ecu settings are ignored above a set load and rpm and you are now in control of the AFR and if not then that is your problem. If you did try this and this is not the Ultimate emanage, then it wont matter because the factory ecu will correct over a a short period of time based on the stock O2 sensor.
1flyex
Apr 10, 2010 05:48 PM
