Why do the underhood fans have 4 relays?
vehicle is in signature:
Why do the fans have 4 relays ... or what is the differences in their function?
I referring to the 2 relays under the hood in the fuse panel that control the radiator and condenser fans; and the other 2 relays off to the side of the condenser fan that also control the radiator and condenser fans?
There is a relay for the compressor, condenser fan, radiator fan, and there is a diode pack that looks like a relay. A relays function is to use low amperage to control high amperage cicuits. If you notice the wires at the fan connectors are a heavy gauge. As opposed to the wires in the control panel are small. It gets into cost of wiring, size of dash switches, size of ECU drivers, and Im sure, the manufacturer doesnt want high amps flowing up and down the harnesses. Why do you ask?
Why do I ask? -- Why have 4 relays for two fans?
The 2 relays to the side of the condenser fan are the AC compressor clutch relay and the condenser fan relay.
RedBull & CivLude:
I think I came to this conclusion by reading some threads in the archives or gotten confused about it too easily. I thought perhaps the engine cooling system and the AC system operated both fans independently of each other. So, when you turn on the AC, then only the condenser fan is supposed to run, not both fans ... correct ?
No, both fans are supposed turn on with either the AC running or with the thermoswitch command.
The AC comp. relay and cond. fan relay are bolted to the radiator bracket. The cooling fan relay is located in the underhood fuse box. The other relay in the underhood fuse box is the power window relay.
So, only one relay per fan but various sensors and switches that turn them on, correct?
Kevonn Martin
Apr 26, 2018 08:03 AM
Linh.
32
Dec 18, 2005 11:21 AM
AgentJam
Jul 1, 2005 05:23 AM
