hard to put in gear
Old Apr 9, 2010 | 07:54 PM
kris9's Avatar
Default hard to put in gear
Old Apr 9, 2010 | 08:15 PM
Ricextacy's Avatar
Default Re: hard to put in gear
if it shifts fine when the car is off... i would blame the clutch.
i had the same problem and i got a new clutch kit and its all good.
Old Apr 9, 2010 | 08:34 PM
Adi_King's Avatar
check and see if the transmission has fluid in it would also cause problems shiftin
Old Apr 9, 2010 | 10:49 PM
Fo-Do Fanatic's Avatar
Did you just put a short shifter in?
Old Apr 9, 2010 | 10:59 PM
Nickstadx's Avatar
i had the same problemo, soe new tranny fluid did the fix right away. until i found out my Main imput shaft bearing went out, thats why i didnt have any fluid in the first place lol
Old Apr 9, 2010 | 11:59 PM
Matt91's Avatar
you might just try simply adjusting the clutch... could be as simple as that...
Old Apr 10, 2010 | 02:46 PM
NGUSPEED's Avatar
Im experiencing the same issues with mine. I have a stock '90 Si Hatch w/ just under 170k miles on it. I've replaced the transmission fluid and it wasn't burn, discolored, or low. I notice when I drive the car first time in the morning the shifts are ok, its after a few miles of driving when the car warms up that gear selection gets tough.
Im speculating either the clutch and/or shifter bushings
itr1244
Sep 29, 2014 12:52 PM
arielb1
Dec 12, 2009 01:34 PM
01_S2k_Driver
Feb 7, 2005 04:23 AM
tyflip2
10
Nov 14, 2003 11:49 PM
Jesse H
Aug 20, 2002 05:04 PM
