96 Civic fuel sender location?
Old Apr 9, 2010 | 06:37 PM
VihnSta2's Avatar
Default 96 Civic fuel sender location?
Where can i find this? I broke my fuel gauge needle in my cluster and now i bought a pod gauge but i need to tap into the fuel level sensor And or fuel pump. Any ideas? Maybe a diagram please?
Cheers
Old Apr 10, 2010 | 07:02 AM
VihnSta2's Avatar
Default Re: 96 Civic fuel sender location?
Morning bump.
Common, I'm sure someone's installed a fuel gauge. I can't be the only one in the world that broke a needle in his cluster. I just need to know what wire in the engine harness i could tap into for the fuel sensor. I've opened my cluster already and tried every wire in it and none seem to work. I think i just have to tap in directly into the fuel sensor wire. Anyone?
Old Apr 10, 2010 | 07:17 AM
vtechjunkie's Avatar
The fuel sending unit is in the tank. It would be easier to replace that than to nstall that new gauge. Take that back and pay for a new sending unit.
Old Apr 10, 2010 | 07:24 AM
shocker911's Avatar
he broke the needle on his cluster how would replacing the sending unit fix that?
the sending unit is under your back seat there is 4 screws to remove the cover plate then its like 8-10 10mm nuts that you remove then there it is
Old Apr 10, 2010 | 08:13 AM
VihnSta2's Avatar
The fuel sending unit is in the tank. It would be easier to replace that than to install that new gauge. Take that back and pay for a new sending unit.
Lol, Thanks for acknowledging my post atleast
Sweet, Thanks man that was really helpful I guess i'll try that now, Hopefully it will work. I'm already in this $60
Old Apr 10, 2010 | 12:09 PM
VihnSta2's Avatar
Well, ****..I've tapped into all the wires going into the sensor. The only wire that worked just gives me a fuel reading when i'm stopped..Then when i press on the gas it goes all over the place.. Any ideas of where i should tap the wire to, To get an accurate reading?
Does anyone think i should just remove my cluster and try tapping into all the wires that went into my fuel gauge again? Cause i did it before and didn't get a reading..Anyone know what color wire to be looking for?
Old Apr 10, 2010 | 02:01 PM
VihnSta2's Avatar
2hr bump
I need to get this thing to work soon or else i'm going to be stranded somewhere. :[
Old Apr 11, 2010 | 10:44 AM
VihnSta2's Avatar
Afternoon bump
Old Apr 12, 2010 | 11:35 AM
VihnSta2's Avatar
Next afternoon bump
Anyone :]
Old Apr 12, 2010 | 01:51 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Um, your problems would be over much faster if you just replaced your OEM fuel gauge in the cluster ... rather than farting around with an aftermarket thing? No?
Old Apr 12, 2010 | 06:03 PM
VihnSta2's Avatar
Yeah, I thought of that i'm sick of buying aftermarket ***** for my car but you can't just replace the only gas gauge in the cluster it's not a gauge face..The needle is on the cluster itself i would have to buy a whole new one and that's expensive.
Old Apr 12, 2010 | 06:09 PM
92lxsleeper's Avatar
an aftermarket gauge is never gonna work on a stock sending unit. you need the sending unit that is made for that guage.
Old Apr 12, 2010 | 06:11 PM
does your car have a factory tachometer or not?
if it does not have a tach, only the speedo and a big coolant and big fuel gauge, then ill send you a fuel gauge for $25 shipped anywhere in the 48 lower USA
Old Apr 12, 2010 | 06:12 PM
VihnSta2's Avatar
Lol, No offense..But i don't see where you get your information from. I know not all gauges are universal. This gauge is compatable with the OHMS that my fuel sender sends.
Well, I guess i'm not going to get my answer from anyone. So i'll just save up for an oem cluster thanks all!
Cheers.
Old Apr 12, 2010 | 06:14 PM
VihnSta2's Avatar
Lol, Thanks but it's cool i'll just save up..What i'm most pissed about is that i can't return this gauge back..It's too much of a hassel.
PrettyMicky951
May 13, 2009 09:46 PM
JDM_Spec_SI-R
Sep 20, 2006 05:53 PM
foam
Mar 6, 2006 10:20 PM
drunknbass
Aug 7, 2003 04:06 PM
