Classic Hondas All Pre-1988 Hondas.
got a 86 honda crx carburated gets all choked up on take off
Old Apr 9, 2010 | 10:37 AM
robh1692's Avatar
Icon6 got a 86 honda crx carburated gets all choked up on take off
I got a 86 honda crx from a guy on craigslist. think it is a junkyard frankenstien. When you take off falls on face. replaced fuel filter drained and refilled tank with gas e10 also. replaced cap and rotor. Used a half a can of b12 on carb. Any fresh ideas would be welcomed. gonna get on bass boat and think about what to do next.
Old Apr 9, 2010 | 10:39 AM
robh1692's Avatar
Default Re: got a 86 honda crx carburated gets all choked up on take off
big thanks to this site gotta a haynes manual dosent say anywhere what firing order is found it here
Old Apr 9, 2010 | 09:54 PM
cbstd's Avatar
Check the cam timing. When the cam belt gets old, it might slip a tooth and make it run as you have described. Also, check for vacuum leaks.
There is a factory service manual online at www.redpepperracing.com
Old Apr 10, 2010 | 04:49 PM
robh1692's Avatar
thats good didn't even think to check timing. might make life easier. gonna try that then replace timeing belt and if that don't get it gonna put a weber carb on it. need to get this thing going
Old Apr 11, 2010 | 04:28 PM
robh1692's Avatar
checked the timing and and put a vacum guage on it the timing was on and had 20 inches of vacum then it warmed up and dropped down to 10 to 12 inches of vacum making me mad i know those boxes on firewall is full of vac switches do they go bad often and what controls them don't think car has ecm thinking of cuttin off vac lines and pluggin them off any more ideas anybody oh i did advance timing 12 degrese to get vac back and ran better know that is too much guess would be easier to just buy 50 ft of vac line and re do it all
Bryant_novtec
Jan 13, 2014 01:09 PM
mase1386
Jan 8, 2011 01:56 PM
threehonda
Classic Hondas
10
Jul 12, 2009 05:17 PM
Its me DUB
May 2, 2008 06:58 PM
sidewayz32
18
Oct 25, 2005 04:06 PM
