Sticky throttle body
Old Apr 9, 2010 | 08:33 AM
Singlecam4dr's Avatar
Default Sticky throttle body
Ok so I am useing a b16 throttle body on a y8 manifold. I cleaned it out before installing it and lubed it up a little hopeing it would help, well no it still has the problem. I have to push the throttle hard to get it unstuck to drive. It use to be worse but that's when I lubed it thought it would help turnin the adj screw for the stop up some but no it didn't. Reset the tps and well no now I have to punch the pedal to free It up and it's good to go but I don't like that at all!! Not mention but when I depress the brake the idle goes up a little but that's not the problem. Any ideas for me to try would be sweet thanks for looking!!
Old Apr 9, 2010 | 09:10 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: Sticky throttle body
Do you have the correct throttle cable?
Old Apr 9, 2010 | 11:35 AM
1991civiczc's Avatar
my rpm goes up aswell once i press the brake pedal in. its normal. as for the sticky feeling?? use some carb and choke cleaner on it and try to loosen it up
Old Apr 9, 2010 | 12:03 PM
sh!ft's Avatar
Who the fack changed my title?!
you have to completely take apart the throttle body. butterfly shaft and all. what i did was sandthe actual housing and the butterfly with some fine grit sand paper and put everything back togeather, worked fine for me after that
Old Apr 9, 2010 | 12:54 PM
gringo7718's Avatar
Depends where it is binding.
If it is binding in the shaft, you have to take it apart and lube that.
If it is binding because the butterfly is hitting the housing you can lightly sand it so it doesn't stick. This may require you to readjust your idle if you sand too much.
Old Apr 9, 2010 | 01:42 PM
Sweet thanks for the replies!!! Good info I thought I may have to take her apart and fiddle with it. Now that I know I should I'll be doing it tommorow after fittment of new new frontend parts!!! Thanks again dudes
monkalotamus
Nov 15, 2006 06:31 PM
Des9255
Oct 24, 2005 09:58 PM
mkinpwrat12g's
Sep 1, 2005 07:12 AM
1QWKGS
Apr 3, 2005 11:52 PM
miahmouse
Oct 7, 2002 09:24 AM
