REALLY hard to get into gear, what's wrong?!?
Old Sep 9, 2002 | 11:47 PM
NickGSR's Avatar
Default REALLY hard to get into gear, what's wrong?!?
For some reason today my car would not go into gear. I'd pull up to a stoplight and try to go into first and it wouldn't go in. Now I can get it into gear but i have to force it quite a bit. 42k miles on my gsr tranny with probably 60 1/4 mi passes at the track. I have a brand new ACT clutch so don't tell me my clutch isn't working. Thanks.
Old Sep 10, 2002 | 03:00 AM
H23 Power's Avatar
Default Re: REALLY hard to get into gear, what's wrong?!? (NickGSR)
try bleeding the clutch line some
Old Sep 10, 2002 | 04:28 AM
rice a rona's Avatar
Default Re: REALLY hard to get into gear, what's wrong?!? (F23 Power)
bad synchros...but honestly, it has to do with the clutch most likely. Sometimes with race type clutches, they make it harder to get into 1st and reverse.
Old Sep 11, 2002 | 02:54 PM
NickGSR's Avatar
I bled the clutch slave cylinder today and I thought it fixed the problem but it started doing it again. Here's what happened, tell me if you can make sense of this... I got into the car, pressed down the clutch (car is in 1st gear) and cranked it over and the car jumps forward like I didn't have the clutch in! I was like wtf? So i put it in neutral and started it and then it wouldn't go into reverse. Today when I got in the car and started it (car is in first gear) when i let off the brake it started moving forward like the clutch was semi-engaged (keep in mind the clutch is depressed to the floor). But after I drive it a block it goes away and goes into gear just fine. Then I'll pull up to a stop light and it won't go into gear again.. what is wrong with my car?!? fyi: I had an act 6 puck clutch put in about 1500 miles ago and it has been working great until now? Could they have messed up the installation? Give me some ideas. Thanks, Nick.
Also, when the car is off it goes into gear fine. If i start the car while its in gear it's hard to pull out of gear.
[Modified by NickGSR, 11:56 PM 9/11/2002]
Old Sep 11, 2002 | 06:03 PM
kentucky accord's Avatar
somewhat common problem with act or any heavy duty clutch. i had a similar problem with my car and all it took was a slight adjustment. hydrolic clutches do not have the same adjustment properties as a cable tranny but you can adjust them, or how/where they engage.
your clutch pedal will have some adjustment screws on it. get a shop manual or have someone adjust those until your clutch is acting the way it should.
if that doesnt work, i would go to the slave cyl. next. thats a simple fix as well.
worst case, its the fingers on your pressure plate, highly unlikely though being that its so new.
Old Sep 12, 2002 | 11:37 PM
saso
Guest
Posts: n/a
Default Re: REALLY hard to get into gear, what's wrong?!? (kentucky accord)
input shaft bearing
Old Sep 12, 2002 | 11:40 PM
NickGSR's Avatar
Default Re: REALLY hard to get into gear, what's wrong?!? (saso)
allright, now explain to me what the hell that is
How can I tell if its that and not something else and how do i go about fixing it?
Old Sep 13, 2002 | 02:12 AM
ninesecrx's Avatar
I personaly think its a faulty clutch. Call act and explain whats going on to one of their tech and maybe theyll send you a new clutch. All very nice guys down there.
Old Sep 14, 2002 | 02:34 AM
saso
Guest
Posts: n/a
open up the tranny look for scrap metal
Old Sep 15, 2002 | 06:01 AM
AussieK24's Avatar
How about the input shaft binding in the bearing in the centre of the flywheel. That way the input is still spinning ever when the clutch disengages it.... Just a thought...
Old Sep 15, 2002 | 05:26 PM
NickGSR's Avatar
Default Re: REALLY hard to get into gear, what's wrong?!? (b16a4me)
Fixed it. The slave cylinder just needed to be bled (the RIGHT way).
CWTegRNo.160
Jul 27, 2005 03:25 PM
Jeff_B
Dec 10, 2004 09:21 AM
92B20GSR
Mar 19, 2004 11:23 AM
kydragger
Feb 17, 2003 10:55 AM
