Suspension question 93 sol
Old Apr 8, 2010 | 05:23 PM
sLAg's Avatar
Default Suspension question 93 sol
Seems like my front suspensions gone so my question is I got a 93 del sol nd a usdm integra R full suspesion off a 5 lug Lying around would it fit ?
Thanks in advance
Old Apr 8, 2010 | 06:29 PM
theBEST's Avatar
Default Re: Suspension question 93 sol
yes it will bolt-up ...ur welcome...
Old Apr 8, 2010 | 06:44 PM
sLAg's Avatar
Will I need the itr lca or would mine work? Thank you ^
Old Apr 8, 2010 | 06:48 PM
sLAg's Avatar
Oh the itr suspension is off a 01 idk if that matters does it?
Old Apr 9, 2010 | 07:59 AM
Red_Army's Avatar
no pretty sure it doesn't. should still bolt up all ok. you got the 5 lug all they way around? thats alotta work for just shocks/struts.
Old Apr 9, 2010 | 03:18 PM
98civdx's Avatar
Master Detailer
You do need ITR spec lca's for ITR shocks to fit, whether ITR lca's will fit or not i have no clue.
Old Apr 9, 2010 | 05:32 PM
sLAg's Avatar
No Im not putting the 5 lug on just the shocks/ springs
Old Apr 9, 2010 | 09:17 PM
forcefedferio's Avatar
Yes the ITR spindles/trailing arms will fit fine.
You will need disc brake e-brake cables if your sol was not originally equipped with rear discs.
You can re-use your stock LCA's, both front and rear.
Old Apr 9, 2010 | 09:19 PM
sorry, just read that beer and late nights makes reading own me.
the ITR front springs/struts will work, for the rear you will need to use the ITR rear LCA's but other than that they will bolt up.
Old Apr 9, 2010 | 09:34 PM
sLAg's Avatar
Thanks a bunch guys
CaRb0y
May 11, 2009 03:00 PM
Del_Sol_s
Jul 22, 2005 09:24 AM
transitions
Jan 27, 2005 06:49 AM
naujcdl
Apr 18, 2003 09:48 AM
ITR Demon
Feb 5, 2003 08:15 AM
