civik ek 96-00 bilstein to EG2 Del Sol??
Does Bilstein even have a separate rear part number for 96-00, or do they just use the spacers like some other manufacturers? If so, they should go right on.
If not, see above
If not, see above
IF your shocks are 96-00 spec
Then the first poster under op is correct.
You will have to shave rear .25mm- .30mm thickness
If your shocks are 92-95 spec then the second poster is correct with washers
94DS
May 15, 2011 04:09 AM
opera936
Apr 27, 2009 05:18 PM
Tuesdaynightfever
Mar 22, 2006 10:17 PM
