Suspension & Brakes Theory, alignment, spring rates....
Which ABS ring for CircuitWorx Stage 1 Axles?
Old Apr 8, 2010 | 02:06 PM
xrdriver's Avatar
Default Which ABS ring for CircuitWorx Stage 1 Axles?
I've had these CircuitWorx Stage 1 axles in my EG with a turbo GSR for a while but I bought a 2000 Integra GSR and I am swapping everything over.
The GSR comes with ABS so I would like to take advantage of it. The problem is that my axles do not have ABS rings so now I need to buy the ABS rings but I don't know which ones to buy. I contacted CW and they were very fast to respond and told me that the outer CV is from an Accord but they could not tell me which year or model.
Does anyone know which ABS rings I should be buying? They use a 36mm axle nut and I measured the OD of the outer CV and it is 3.592" which doesn't seem to be the same as either an Accord or Prelude. Can I get these from anywhere other than Honda?
Old Apr 8, 2010 | 08:15 PM
k7q's Avatar
k7q
Default Re: Which ABS ring for CircuitWorx Stage 1 Axles?
i dont think you can use your ABS with the axles that you have. Accord and integra ABS placement are different.
bob441
Nov 11, 2015 06:50 PM
tso
Nov 25, 2007 11:49 AM
nihad
Jul 21, 2007 09:38 PM
charjacq
Mar 2, 2003 09:21 AM
ILOVEGIRLS
Mar 27, 2002 08:36 PM
