stuck axle nut
yeah or get a impact if u have access
1000 pounds of tq should do the trick
i always use a breaker bar and then a 5 foot pole on that breaker bar.
some cars u wil need an impact though, ive broken breaker bars and ive bent then soo much that they were not usable
When I did mine I was turning it so hard the wheel was actually spinning on the ground. I had some one get in, hold the brake, 2 ft bar with a 3 or 4 ft pipe, then I hung on and pulled as hard as I could a few times, eventually falling on my ***. but it came off.
Yup, it is all about leverage and locked brakes. You still may consider yourself lucky, because it will let go soon or later, but at least it is tight. I undid mine with 3/8" ratchet and no leverage what so ever. If it wasn't for those bent tabs it was just a matter of time when I would see my front wheels passing me on the highway.
Good luck.
Good luck.
also a good impact will help but if you don't have a good compressor it won't matter. you need to have a compressor with a high cfm output.
Good luck.
Good luck.
to take it off i just stick a screwdriver in the brake rotor so it doesnt turn, on the top of the rotor theres air holes to cool the rotor so i just stick something in there
The one time I really had issues getting an axle nut off, I ended up drilling six holes in it, one at each point, and that was what it took.
no not really, ive put 10,0000 miles on the car without a problem.
So you tightened it more than what you say. My point is that you shouldn't go around spreading mis-information, that it doesn't need to be tight, when in fact it is supposed to be pretty tight, 134ft-lbs like Rue said.
So by that logic, when you do a timing belt you use a 1/4" drive ratchet for the crank bolt, right? I mean it's only 83ft-lbs, just snug it up...
i use common sense. sure you can tighten it to 130 pounds, good luck taking it out. I tighten it snugg and indent it, anyone with common sense knows that it will never come out
i want one lol
