Omni 2K high build THE WORST EVER!!!
Old Apr 8, 2010 | 08:18 AM
kreatekustomz's Avatar
Default Omni 2K high build THE WORST EVER!!!
I don’t know if anyone besides me has ever used Omni products before. If not let me enlighten you on Omni. Basically it’s an off brand made by PPG which allows the prices to be cut in half on almost ALL products. I know in the painting industry this isn’t always good giving life expectancies of the final product, sag, adhesion, hardness, and so forth. But the price was enticing to me...I have now used 4 different brands of paint, Martin Senior (and other Napa brands), PPG, HOK, Sinks. All of which did a great job with adhesion...
With Omni the only thing I would say I liked was the basecoat... I just go done spraying their "Epoxy Primer." Everyone else that sold it was a multi surface adhesion product. NOT FOR OMNI. Complete surface prep of 320 and the product didn’t adhere (had to remove all the material.) 3 days ago I neglected this event and tried spraying Omni 2k high build. For starters it’s designed to roll on not spray. I used a 2.0 HVLP tip with 10% reduced and still couldn’t get it to optimize. The surface was 220 painted/plastic prepped. Well no adhesion once again. Again all other products I've used in 2k was a multi surface adhesion. So all of that had to come off.
I'm tired of it and will never use Omni again.
Old Apr 9, 2010 | 09:02 AM
jdg1986's Avatar
Default Re: Omni 2K high build THE WORST EVER!!!
Why did you spray an epoxy and a 2k highbuild?That could be your problom.I spray EXTREMELY LIGHTcoat of etching primer on BARE METTAL and then 2-4 coats of 2k primersurfacer.I feather edge my bodywork with 180,then 320 before I spray primer on.Did you feather edge the panel properly?Mix the product with the correct amount of hardner?What went wrong?I used ppg's shopline,omni,deltron,and global products,and I never had a problom with any of it.What do you mean by "multi surface adhesion"?Are you talking about an adhesion promoter?
Old Apr 9, 2010 | 09:15 AM
nsxter's Avatar
yeah omni sucks , i only use glasurit nothing else
Old Apr 9, 2010 | 12:19 PM
mztykal's Avatar
You guys are weird. It's all about the prep. I've used Omni/Shopline on customers cars when they didn't want to spend the money for better stuff. Works fine for the past 3-4 years.
You're probably using it wrong.
Old Apr 10, 2010 | 04:30 PM
jdg1986's Avatar
It really is all about prep,and choosing the right product for the right application.Primer is not just primer,there are all sorts of different types of primer,all for a different application.You cant expect to block a primer sealer,or throw a 2k primer surfacer on bare mettal.You need to know what you need for the job.
Old Apr 10, 2010 | 06:17 PM
-16V-'s Avatar
While were on the subject. Can u use rattle can etching primer under a 2k surfacer. Someone told me for bare metal is to shoot it with a sealer first then 2k it.?
And what 2k surfacer would u recommend?
TIA
Old Apr 12, 2010 | 09:10 AM
jdg1986's Avatar
You use etching on bare mettal,then a polyester primer(for blocking),then a 2kprimer surfacer(I never use a polyester primer,I just shoot it with a 2k primer surfacer and block that).You can use spray can etching primer,but If your planning on spraying over a large area then I wouldnt reccomend it.You can buy it buy the pint at your paint dealer.Allways spray 1 light coat of etching primer over bare mettal(you shoul be able to see through it),then a primer surfacer.I would talk to your paint dealer to determine what product will fit with your budget.
Old Apr 12, 2010 | 03:14 PM
LsEjCoupe's Avatar
omni clear has worked pretty well for me but i havent used any other product by them, and i agree to the above who said "its all in how you prep the area or areas....
Old Apr 13, 2010 | 05:43 PM
yeah the area was prepaired properly...
Have any of you used the 2K high build from omni? If so could you spray it or have to roll it on? I was using a 2.0 tip and still couldnt spray it...
Old Apr 14, 2010 | 12:49 AM
mztykal's Avatar
285 sprays perfectly fine from my 1.8 Iwata. Maybe you're doing it wrong, never heard of rolling it on before.
Old Apr 14, 2010 | 09:34 AM
nsxter's Avatar
dud are you dumb or do you just not realize there is different quality paint , that has nothing to do with prep , thats why paint has different prices , omni is a low end quality
Old Apr 14, 2010 | 09:57 AM
rs250nut's Avatar
Did you stir the can of primer first? Did you strain it? **** in the gun? If you cant get primer to come out of a 2.0 fluid tip your doing somthing wrong however cheap it may be.
Old Apr 14, 2010 | 01:50 PM
jdg1986's Avatar
The primer should spray out just fine if your using a 1.8 tip or larger.Yes,you can roll the primer on,It nice to fill in pinholes in the bodyfiller and it keeps overspray off the car,but you half to be carefull.You will need to do a bit more blocking if you roll it on.
Old Apr 14, 2010 | 02:56 PM
dc5r2002's Avatar
Never had any problems with the omni.
I like to use the evercoat slicksand primmer. A good high build and its only about $85 dollars a gallon. sands nice too.
Old Apr 14, 2010 | 03:01 PM
like I said, I tried spraying the 2k with a 1.8 tip and couldnt spray it. Bought a BRAND NEW gun HVLP 2.0 tip. Paint mixed according to manufacturing specs + allowable 10% reduced, strained... Its not sprayable I can promise you that.
Old Apr 14, 2010 | 09:27 PM
-16V-'s Avatar
Thanx for that info jdg1986.
Old Apr 15, 2010 | 01:03 AM
mztykal's Avatar
Are you retarded? Did you read any of the posts? He's having a hard time spraying it and blaming the brand, how's that a paint quality problem? He's also having adhesion problems which is based off how you prep.
Whats your problem? How does how expensive a paint is make it better for his situation? If he bought 300 dollar epoxy, does that mean it'll guarantee stick? NOPE.
Retarded post.
Old Apr 15, 2010 | 01:05 AM
mztykal's Avatar
Are you sure your gun settings are correct? If you're getting nothing coming out or it's barely coming out, you sure you know how to tune a gun?
Look in the cup, there's a little plastic filter in there, take it out. See if that helps you.
Old Apr 15, 2010 | 02:56 PM
I didnt take the filter out, but yes I know how to adjust the gun as well as the other 4 guns I have.
Also, I have bought the exact same product in other lines using the same preperation process and have always have great adhesion results.... The only thing I could think is I left the paint in my shop over the cold winter. Maybe thats the problem, however; the 2k can only be rolled on.
Old Apr 18, 2010 | 11:04 AM
Ziprock's Avatar
ive used omni etch, high build, sealer, and clearcoat. i didnt have any problems with it.
slowboyy06
Paint and Body
Nov 30, 2009 10:13 PM
DC206R
Paint and Body
Sep 12, 2009 06:48 AM
redsolturbo
Paint and Body
Jan 25, 2009 08:40 AM
CRMB
Paint and Body
Jul 24, 2008 08:30 AM
Tenners
Sep 9, 2005 01:15 PM
