Serious Nitrous with Turbo question...
Old Sep 9, 2002 | 10:19 PM
PrecisionH23a's Avatar
Default Serious Nitrous with Turbo question...
This is just an idea, but i am pondering the thought of adding nitrous to my current set up, reducing intake temperatures by 75 degrees is always a plus. I should be dynotuned next friday and hopefully ill be putting down 400 to the wheels. I run the hondata 4b with a FULLY built motor and im not very familiar with how it runs its ignition and fuel curves for turbo with nitrous. I would imagine i need a different chip setting for just turbo and a diff for the turbo + nitrous, correct? As far as a set up, a wet set up with direct port is the way to go from the searching ive done. Does anyone have first hand experience with this set up? Like i said, this question is more out of curiosity rather then it being a possibility.
Old Sep 9, 2002 | 10:55 PM
saso
Guest
Posts: n/a
Default Re: Serious Nitrous with Turbo question... (GudeH23a)
I have used single fogger and direct both work well but for different apps. If going with high boost (like 20psi+) or want extra safety go with direct. However i have used a sinnle fogger running high boost and it worked well. At the end of the day ive been told that with direct port's even distribution you are prob. safer.
Old Sep 9, 2002 | 11:01 PM
Smashback's Avatar
Wet setup is always the way to go....should be easier to work out the fuel delivery for also in conjunction w/turbo.
Old Sep 10, 2002 | 06:28 AM
93LSivic's Avatar
Damn Anthony. Couldnt ask this question at any better time then now. I have been kicking this very same thought around inside my head as well.
Direct port staged nitrous kit sounds fun
Old Sep 10, 2002 | 07:42 AM
boosted3g's Avatar
Default Re: Serious Nitrous with Turbo question... (93LSivic)
My last motor i was running a 120 shot on top of 22 psi and it was a tuning nightmare. I ended up scraping the nitrous after destroying my bottom end. A larger turbo is the way to go.
Old Sep 10, 2002 | 04:35 PM
93LSivic's Avatar
Default Re: Serious Nitrous with Turbo question... (boosted3g)
Josh, you have Naaaawss???? Wanna sell it, you know you want to
Old Sep 10, 2002 | 04:37 PM
sutrusu's Avatar
have you considered the intercooler sprayer? it takes intake temps down A LOT and you dont run the risk of spraying it into your engine. i think nitrous express has a kit.
Old Sep 10, 2002 | 04:38 PM
What engine management were you running while trying to tune the nitrous and turbo? I dont particularly like nitrous that much, i think it is cheap horsepower but it does has its advantages for a turbo application. yes it also has its disadvantages.
Old Sep 10, 2002 | 04:39 PM
93LSivic's Avatar
Josh is running a Power FC
Old Sep 10, 2002 | 07:07 PM
boosted3g's Avatar
yeah Dan i had the nawwwwzzz. I ended up selling it to a guy on the board actually, itr206 (very cool guy, he even has a type r). It was sweet, NOS Pro Rage Fogger. If anyone is looking for a kit that is the one to get, it is excellent.
quik sol
Jun 12, 2009 02:08 PM
FATBOYeg6
Dec 28, 2005 06:02 PM
BrokeDwnHnda
Jan 7, 2004 01:10 PM
Lewie
Feb 6, 2003 06:11 AM
