rear main seal
Old Apr 7, 2010 | 06:06 PM
ntrider's Avatar
Icon6 rear main seal
Hey guys quick question to anyone that has ordered a rear main seal from hondaautomotiveparts.com.
I need one for 93 dx hatch d15b7 and have looked for it but cant seem to find it. Did search here and all i can find is the part # for the del sol s. I believe it also had the d15b7 (si had d16z6) in it but need confirmation.
Thanks
Steve
Old Apr 7, 2010 | 06:15 PM
Matt93eg's Avatar
Default Re: rear main seal
Correct, the Del-Sol S came from the factory with a D15B7. Si trim was the D16Z6 and the VTEC trim was a B16A3.
Old Apr 7, 2010 | 11:33 PM
ntrider's Avatar
Cool thanks man. where on the website would one find it? I see it in the gasket kit for the block in the 96-00 years, but for 92-95 its not shown. Other then the gasket kit where else would it be?
Old Apr 8, 2010 | 12:04 AM
RICKSAUTOMOTIVE's Avatar
there are 2 oem numbers on the 93 dx 1.5 Liter engine. a 33 ARAI (IDK what that means) is 91214PH3751 and the other, a 33 NOK (IDK what hat means either) is 91214PLE003
Old Apr 8, 2010 | 12:16 AM
DCRB's Avatar
i thought they were generally included with a gasket set, since you have to drop the oil pan to remove the rear main because the oil pan bolts to the bracket that holds the rear main, which means you should have to replace your oil pan gasket too.... might as well do the others too
blitzinq
Engine Machining & Assembly
Oct 3, 2016 10:48 PM
blitzinq
Oct 2, 2016 11:08 AM
boost and bass
Apr 26, 2009 08:07 PM
sireg6
Mar 10, 2008 06:22 PM
volkswagentuned
Sep 8, 2006 11:58 AM
