Header paint doesnt work
Old Apr 7, 2010 | 04:47 PM
b18c1hatch1992's Avatar
Default Header paint doesnt work
Ok so i posted on here a few days ago about cleaning up my header. So i took the header off and then blasted it, sanded it all down and did every step i was supposed to take to prep this thing. My only problem is that i didnt have an oven to bake it in after i painted it. But it clearly shows that there is a way to do it while its on the car so i followed those steps and heres what i have now...
Here we are before startup
And 2 minutes after startup
Stayed pretty much the same so far but i've only driven it around for the 30 minutes that it says on the paint..
Old Apr 7, 2010 | 04:56 PM
DoubleEx's Avatar
Default Re: Header paint doesnt work
seems to me thats not header paint. You got engine paint and it is not a high enough heat resistance
Old Apr 7, 2010 | 05:01 PM
Nah its header paint... its VHT header paint, says its able to withstand 2000 degrees and thats 3 coats on there that burned off in less than 2 minutes
Old Apr 7, 2010 | 05:09 PM
starion88esir's Avatar
Because you MUST preheat it to bake it on. PERIOD. Anytime you apply it before hand it will reach temperatures in excess too quick and there you go.
I say get rid of the red, it's heinous. My opinion is free with my knowledgable answer.
DoubleEx's Avatar
15 minutes at 250°F
30 minutes at 600°F
1 hour at 800°F
30 minutes at 1,000°F
ALL CURING SHOULD BE DONE SLOWLY
Old Apr 7, 2010 | 05:13 PM
raidacaipo's Avatar
interesting but why red? lol I would have used that red on the valve cover instead
Old Apr 7, 2010 | 05:15 PM
99_integra_gs's Avatar
Orchard sells high heat grill paint works great!
Old Apr 7, 2010 | 05:19 PM
kelsodeez's Avatar
derp resistant
i have a strong, justified hatred for VHT. i would recommend never ever to use VHT on any part of a car.
Old Apr 7, 2010 | 05:29 PM
Went with red pretty much just to see how it would turn out, didnt want to go black like i've seen hundreds of times.
Was going to do the valve cover the same color but now i know i'll probably just powder coat it red instead of using that sh** paint.
Old Apr 7, 2010 | 05:53 PM
Matt93eg's Avatar
I agree with starion, i think you should have found an oven to bake it in somehow. It is kinda weird that the paint burned off the #3 and #4 runners before the others, I would think they would have all burned off at the same rate.
As for the comment by one user about VHT paints sucking, I don't have experience with all there paints, only there black wrinkle paint and I used it on my Valve Cover, stripped all the old paint off, 4 coats of VHT Black wrinkle paint, in the oven it went. Then let to cool over night and then put back on and its been holding up great. The valve cover however does not get nearly as hot as the Header.
Old Apr 7, 2010 | 05:56 PM
kelsodeez's Avatar
derp resistant
how long ago did you use vht? they have recently changed their formula and i can say, the old formula was much better of a paint than the new stuff. the way you can tell is when they switched, the new cans have the blue nozzle.
Old Apr 7, 2010 | 06:02 PM
Deetz's Avatar
Crazy Honda Guy
This is not new news! Header paint does NOT work! That's why you rarely see colored headers! When you do see colored headers, it is because they are professionally ceramic coated!
Old Apr 7, 2010 | 06:14 PM
Matt93eg's Avatar
Great Info as usual from Mr. Deetz.
Old Apr 7, 2010 | 06:25 PM
H23_del_soul's Avatar
Oven bake FTW.
Old Apr 7, 2010 | 07:59 PM
92lxsleeper's Avatar
why paint it to begin with? use header wrap, and it will actually serve a purpose. it will cool down the engine bay quite a bit.
Old Apr 7, 2010 | 08:43 PM
96honda_EK's Avatar
Yeah um two things. Red headers dont look good. And dont paint a b series valve cover. It'll never look as good as an OEM red integra type r one. Just buy the real deal
Old Apr 7, 2010 | 08:52 PM
v8killaz's Avatar
i dont know man my header was painted with the same stuff from autozone header paint flat black
and it looks so good in person.
sprayed alot of coats and it looks as the day i spayed it on 5000 miles later
i didnt oven bake anyhting either. I use that paint on everyhting now because the flat black looks so damn good. i just sanded and painted didnt even remove most of the rust and grease and it still sticks
Old Apr 7, 2010 | 08:54 PM
TylerB's Avatar
Originally Posted by DoubleEx
15 minutes at 250°F
30 minutes at 600°F
1 hour at 800°F
WTF is this? Are you saying cure it at 1,000 degrees for 30 minutes?
OP, I like the red.
Old Apr 7, 2010 | 09:36 PM
Kidnkorner's Avatar
I used their nite shades product on my tail lights and it faded in 6 months
Old Apr 7, 2010 | 09:44 PM
JDMP_T's Avatar
get them powder coated if u want the color to stay but it will still change a little w heat
Old Apr 7, 2010 | 09:56 PM
Deetz's Avatar
Crazy Honda Guy
oh, since you were using black, you would not have noticed it turning black, lol
Your right, black always look good!
I was referring to colored sprays.....red, blue, purple ect...
Old Apr 7, 2010 | 11:19 PM
Linked's Avatar
is it ceramic headers or stainless?
i would sand it all down and polish it so get a chrome look
Old Apr 7, 2010 | 11:28 PM
v8killaz's Avatar
i dont know something sounds weird
to the op did u use primer on the header
and my one didnt turn any other color because it was balck but then again it didnt turn any other tone either is stayed flat just like when it dried the first day.
Old Apr 8, 2010 | 04:36 AM
turbodcxbro's Avatar
Anyone think that cylinders 3 and 4 could be running extremely lean? If those cylinders were lean enough that primary would be glowing RED hot, and no paint is gonna withstand that!
Old Apr 8, 2010 | 08:25 AM
zccivic94's Avatar
ur best bet is to actually powdercoat it
