head stud Q
i know that lots of B-series stuff is interchangeable. I called summit to order head studs for a B16A--- to my surprise DOUG said that ARP does not make them for that application. Knowing that things ARE in fact likely to be interchangeable, DOUG said ARP DOES make studs for a B18C1....hhmmmmm
WILL THEY WORK EXACTLY THE SAME????? or are the diameters of the studs different?
I'm not an expert on this ... but "people" seem to recommend stock over ARP for an ITR, plus the deck height is just a bit lower on a B16A than B18C.
Check with sgT or Importbuilders ....
dont use b16a bolts in a b18c, you wont get enough thread engagement.
as far as studs, the b18c studs may work. you might need 2nd set of washers if
you are trying to put them in a b16a.
