Is there any rear lower tie bars for accord 98-02?
Old Apr 7, 2010 | 03:26 AM
WildcatDanny's Avatar
Default Is there any rear lower tie bars for accord 98-02?
Can't find any on ebay.
Old Apr 7, 2010 | 07:45 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Is there any rear lower tie bars for accord 98-02?
From what I've seen/read for the 94-97 the factory bracing is more than sufficient and a lower tie bar is superfluous. I would imagine the 98-02 is similar, so the product may not even exist. If it did probably like DC Sports would have them.
Old Apr 7, 2010 | 08:22 AM
hondamark35's Avatar
i've looked pretty closely at the sub-frames and bracing on the 98-02 and they are pretty stout pieces, the front is improved over the 94-97 and the rear is all-together better than previous models.
most bracing on the underside will only serve to take up space and add extra weight. the front upper strut bracing could be swapped for the CL/TL full brace.. or modified as such. and the rear upper bar added if parts are available (or fabricated)..
Old Apr 7, 2010 | 08:28 AM
if you do however want to spend the money, >here< are some
Old Apr 7, 2010 | 02:55 PM
02_CG6's Avatar
ebay and tasauto have them..
Old Apr 7, 2010 | 04:44 PM
361 accord's Avatar
yeah the subframes on the CGs look hella beefy
what front upper barr off of what? pics?
Old Apr 8, 2010 | 03:09 AM
i don't know everything it came one, but i know i've seen it on Acura Cl and maybe TL, around the same year as the 98-02 accords. if i understand correctly they all shared the same basic platform/chassis architecture.
i just found this pic on google, 3.2 CL with the strut bar or brace. if you recall the 98-02 accord has two curved braces between the strut towers and the firewall. the part on the CL has the same two pieces with the bar you see welded to them.
EDIT: i just thought to check hondapartsunlimited.com
#22 in the image, front strut brace about $50 new..! part #74180-SOK-A00
and to the OP: that rear subframe in the image is the same for the accord. you can see why you wouldn't need a tie bar.
Old Apr 11, 2010 | 04:30 PM
toofastaccord23's Avatar
You should just buy a rear sway bar from an 04 tl it bolts right up to any 98-02 honda accord coupe and sedan there only 40 bux shipped to your door way better than those generic lower tie bars for more information check out 6thgenaccord.com
sinister2c
Jan 31, 2013 08:06 AM
aleks77
Aug 18, 2005 04:29 PM
jarel
Jul 17, 2002 09:29 PM
