Help Key On Deck wont even turn on????
Old Apr 7, 2010 | 12:37 AM
EG-SIXV-TEC's Avatar
Icon2 Help Key On Deck wont even turn on????
Pls help, it was working before
my civic got a kenwood deck i took it out
and idk my friend wanted to test another deck that has a different plug. My current plug wont plug up to his deck so he plugged pins into the red and yellow for power up his deck he had and chassis ground.
That deck didn't work and i don't know if it even had good connection inside the plug. idk if the yellow/red wire or ground got connected or what together or what. I didn't want to cut my wires so he said its fine to test it by sticking the pin inside and connecting it with his soldered wires...
i then put back my own kenwood deck and now it don't even power up or light up. note- took face plate off the even red blinking light don't work.
Please help me honda tech what do i check i checked the radio cigarette lighter fuse but it looks good...What to do????
Old Apr 7, 2010 | 01:35 AM
First.EG's Avatar
Default Re: Help Key On Deck wont even turn on????
test to see if there is power running to the yellow wire with the car off and the red one with acc on and make sure ur fuse is ok just change it for a new one even if its ok
Old Apr 9, 2010 | 06:26 PM
thanks i checked the other fuse under the hood the brown one was blown 7.5 fuse..
pliskin8
22
Jan 1, 2023 07:39 PM
EG-SIXV-TEC
Audio / Security / Video
Apr 8, 2010 06:02 PM
hatchinprogress
11
Jan 20, 2005 06:58 AM
Luserkid
Jan 17, 2005 08:03 AM
murmur9
Oct 3, 2004 01:38 PM
