Suspension & Brakes Theory, alignment, spring rates....
need a little help doing my disc brake conversion
Old Apr 6, 2010 | 11:35 PM
H.I CTR's Avatar
Default need a little help doing my disc brake conversion
ok im planning on doing a disc brake converison on my 92 dx hatch. im going to upgrade to the gsr front and rear brakes. since my brake booster is leaking can i go with a 94-01rs m/c and booster? also will i need to modify anything for the front spindles to fit with the k swap?
Old Apr 7, 2010 | 11:43 AM
Hondatherdm's Avatar
Default Re: need a little help doing my disc brake conversion
I think you should be good
Old Apr 10, 2010 | 04:34 AM
xero_xero's Avatar
GRS brakes are a 32mm bolt housing(for cv axels) just like your dx front brakes. you will need at least a 15in wheel to clear the caliper. the booster/master cylinder will work fine also, just bleed your brakes thoroughly. do the usual, make sure the new brakes are not warped, the spindles are good, ect. everything else bolts right up. think about replacing your front ball joints while they are out.
Old Apr 13, 2010 | 09:37 AM
project93hatch's Avatar
hey does anyone know if i can put the complete disk set up front and rear off a 99 civic si on my 93 hatch dx if so what would i need to do it right, if so would you please pm me
Old Apr 13, 2010 | 09:56 AM
xero_xero's Avatar
you can put the complete setup off a 99si. you will need the ebrake cables and use your lca off your 93 hatch. alot of people say swap the proportioning valve also, but it is commonly disputed whether you need to or not so it is up to you. just properly bleed your lines.
Old Apr 13, 2010 | 02:11 PM
thanks man so use the e brake cables off the si correct. also the fronts do they bolt right up. what proportioning valve do i need and do i need to swap the m/c too if so what m/c do i need .
Old Apr 13, 2010 | 03:35 PM
xero_xero's Avatar
Proportioning valve - the drum rears come with a 30/30.... Disc rears come with a 40/40. like i said, it is widely debated whether you need to or not, if you have it you might as well swap it, if you dont have it, you dont need to worry.
brake cables are attached to drums or disc, just be sure to unbolt completely, and you may get a set with ABS plugs which you can just disregard. reattach brake cables from the SI and adjust your ebrake.
You dont need to swap the master cylinder, but if you are in the market to replace it, replace it with an Integra RS or GSR NON ABS.
should be it.
Old Apr 14, 2010 | 09:57 AM
thanks man very helpful
Old Apr 14, 2010 | 10:00 AM
oh yea what about the front set up......
Old Apr 14, 2010 | 11:15 AM
xero_xero's Avatar
you can keep your dx brakes, if you upgrade to ls, GSR or Prelude, you will need atleast a 15 in wheel.
Old Apr 14, 2010 | 11:42 AM
will the 99 si front brakes set up work the reason i ask is cause i have a si that i totaled in my garage and im trying to upgrade all that i can on my hatch ...
Old Apr 14, 2010 | 01:24 PM
xero_xero's Avatar
It will swap readily, just unbolt and swap the upper control arm (dont bother separating the upper ball joint unless you plan on replacing), get a ball joint separator for the tie rod end and the lower ball joint. the image below is what it looks like. place it between the ball joint and front lower control arm, and hit it so that it separates from the LCA. repeat for the tie rod end.
Old Apr 14, 2010 | 01:31 PM
thanks man i will let u know if i need any other advice thanks agin
Old Apr 14, 2010 | 01:49 PM
Trey's Avatar
25 Year Member
Do not use that pickle fork (above) if you plan to keep your ball joints. It will tear the dust boots..
You can get this one from Sears for $20. I used it to remove my upper and lower ball joints and tie-rod end. No issues.
Old Apr 14, 2010 | 03:23 PM
xero_xero's Avatar
Either tool is going to work fine.
Old Apr 14, 2010 | 03:52 PM
Trey's Avatar
25 Year Member
They both seperate the joints but the one I posted is more friendly to the dust boots.
Old Apr 15, 2010 | 09:07 AM
cool
Bcurt23
Suspension & Brakes
Dec 30, 2016 03:06 PM
Rikaro
Jan 8, 2009 10:21 PM
sleephondsleep
Apr 1, 2008 08:01 PM
LS AzZkIkr
15
Feb 24, 2008 08:08 PM
Repodevil
Jun 30, 2005 01:35 PM
