Fuel pressure bleeding off
I've got a problem which I believe is the fuel pressure bleeding out of the lines while the car sits for extended periods of time. Enough so that after work or in the morning I usually key on and off a few times to prime everything before trying to start it. If I don't do that it will usually take a couple tries to get it started. I do not have this problem if the car only sits for a short while.
Any ideas?
Any ideas?
