integra with high spring rates and it still bottoms out, what spring rate do I need?
I have a dc4 (coupe) with koni yellows and ground control coilovers. I have 400f and 320 rear but just changed to 550f and 400 rear. My dc is pretty low and actually rides good on the highway but when it comes to little dips and small holes in the highway my car bottoms out like crazy!!!!!!!!!!! Im not sure yet if its the upper control arms or the struts bottoming out, i havent had the chance to see if the upper control arms are hitting (there old skunk2 adjustable by the way).
I dont really care about ride quality, I just hate hearing my car bottom out like crazy everywhere i go.
How stiff of the spring rate would you guys recommend?
Are you sure the suspension or UCA's are actually bottoming out or hitting the shock towers?
I used to run 380 lb. GC springs up front, at the ride height shown below and I had no problems at all, even on rough roads (and there are plenty of those around here). My shock towers have no dents in them at all.
well maybe its my upper control arms. Which ones are you guys running.
my integra is probally 1/2 inch lower than that one ^^^^^. Its also on 15" wheels and the majority of the tire is in the fender well.
i do have koni extended top hats
I run 205/45-16 tires, and I had stock UCA's. Also stock top hats.
Be sure your bump stops are cut in half.
yeah i cut them in half. i didnt want to run the oem tophat because the camber is off pretty bad
is the uca a common problem?
yeah i might have to go back to a stock control arm. Ill probally raise my car up 1/2" and then get a little stiffer spring rate
civic_tuned
May 24, 2004 11:09 PM
