Cam timing after milled head?
Old Sep 9, 2002 | 08:27 PM
Rhetoric's Avatar
Default Cam timing after milled head?
I read it in some post awhile ago, but yet the search isn't pulling it up.
Anyhow, I was wondering how milling the head affected cam timing?
Does it advance/retard both cams 1 degree?
Does the cam degree change when milling the head more/less?
Thanks!
Old Sep 9, 2002 | 08:29 PM
Michael Delaney's Avatar
Default Re: Cam timing after milled head? (G S R)
for your engine, every 11 thou milled requires 1 degree advance.
Old Sep 9, 2002 | 10:00 PM
Rhetoric's Avatar
Default Re: Cam timing after milled head? (Michael Delaney)
Does this apply to B18C5 as well?
Thanks for the help.
Old Sep 10, 2002 | 12:17 AM
MikeSarr_GSR's Avatar
I want to make sure I understand what you are saying MD:
If it was a deg advance for every .0011", if you removed .0010" with
a resurfacing and then installed a .45mm 2 layer HG, you would be
at:
.70mm
-.35mm
.45mm HG - (.0010 x 27.5= .0275mm) which becomes @ ".42mm with mill"
.70mm
-.42mm
.28mm reduced lets say .33mm for ease of argument, or .012" is this 10 degrees of compensation? .012" / .0011" thats a whole TOOTH on the cam gear!
I believe I was told by T.O.O. in an email that for every .44mm removed there is 1 deg of compensation. hence, starting with .70mm HG and 0,0 cam timing
if you remove .0010" which is @ .03mm
and you install a .45mm 2 layer gasket (-.35)
you are at .38mm removed from the head roughly,
close enough to warrant a deg of advance I would
estimate. The .44mm spec was given to me by
Larry about 3 months ago when I asked the same
question. Yes, this law should stand across the B series
family I would imagine.
Chances are I could be wrong, this just seems a bit
befuddling
Old Sep 10, 2002 | 06:43 AM
Default Re: Cam timing after milled head? (MikeSarr_GSR)
who said anything about putting in a 2 layer head gasket? Did I miss that on G S R's post?
0.011 in. is 0.28 mm not 0.30 mm.
Can you relate everything to crankshaft degrees?
If TOO is basing it on 0.44mm on every cam tooth that's 17 thou milled for every 2 crankshaft degrees. How can it be true for all Bseries whenthe deck heights are all different? But B18C's I believe havethe same deck height.
[Modified by Michael Delaney, 10:53 AM 9/10/2002]
Old Sep 10, 2002 | 07:18 AM
JPP's Avatar
JPP
It is not head milling and it is not a B18C1 but installing a 2 layer gasket on my B18C5 retarded both camshaft by approx. 2.5 degrees (5 degrees on the crankshaft).
Old Sep 10, 2002 | 07:35 AM
Black R's Avatar
25 Year Member
.....why not just use a degree wheel and dial it in?
Old Sep 11, 2002 | 10:02 PM
Default Re: Cam timing after milled head? (Black R)
ok I correct myself, as I said I was asking a question. I am cutting through this veil of confusion with a torch and giving you this:
http://www.theoldone.com/components/camgears/
here T.O.O. explains what I was not able to and amplifies what MD was saying erlier. I posted what was said from the page, not from my memory which is safer
anyways. T.O.O.'s own cam gear design allows for gasket and material removal
with keyways to line it up based on this principle.
.012 per degree x 27.5 to convert to mm is .33 per degree mark on a
+10/-10 cam gear. there are 35 teeth on a b series cam cog, 360 degrees
in a circle, 10.28 degrees per tooth.
if you say purchase a spoon 2 layer gasket at .45mm and stock is .70mm
then do the math:
you removed .25 hence you only are 7.5/10ths of a degree advanced dropping
the gasket in. your b series R motor has the same dimensions as a B18C1,
removal of .012" is a rule of thumb based on enginbuilders that know our cars
wether it be a B16, B18 or B20 the cogs are the same size, therefore when you
remove material it is the same across the b series cars. it would be different for
a H or D series I am sure. what cam gear are you running?
if you for instance have a skunk2 gear, you then would advance 1/2 degree mark since it is a +5/-5 gear, which is a 1 degree advance. this should get you past 0,0 a bit but the overlap will stay the same since you are moving the cams the same way.
neofreak
25
Jan 1, 2007 12:33 PM
blowme
Nov 11, 2005 11:40 PM
Griffin@Camtech
Oct 6, 2005 07:08 PM
JDMs1eeper
18
Aug 24, 2003 12:01 AM
MackSpeed-616
Apr 13, 2002 07:56 AM
