Anyone find a good proximity sensor yet?
So I heard bad things about the DEI proximity sensor. Anyone find/using a proximity sensor that works correctly with no hiccups?
Thanks
MantisX
Thanks
MantisX
It depends on what climate your area sees and it typically takes 2 seasons of use to set them up. If I do one in the late spring I have them come back in mid fall to finalize the beam. Same principle for mid summer. The issue is the air density/humidity...it effects the beams radius (summer denser beam is compacted....winter less dense-beam spreads more). What may be perfect in mid July is horrendous in December (beam is now 15' away from car...your neighbors hate you)
I think thats exactly what happened to me. I set mine up in the summer time and during fall/winter, it would go off prematurely all the time. Maybe Ill give another stab at it. I have the AU94T.
Thanks all
MantisX
Thanks all
MantisX
flash69
Honda Civic (2006 - 2015)
May 27, 2010 05:05 AM
MidShipCivic
Jan 30, 2005 10:42 AM
Del_Slowest
Jul 18, 2004 05:53 PM
Undepelo
Audio / Security / Video
Jul 2, 2002 11:51 AM
