AC on and rpms DROP...?
Old Apr 6, 2010 | 08:14 AM
hon-daddy's Avatar
Default AC on and rpms DROP...?
I got a 01 integra type r with b18c5. When i turn on my ac the rpms drop around 200-300 and the motor stuggles to stay on. Im thinking its the alternator but anyone have experience with this problem or know whats wrong with my car??
Old Apr 6, 2010 | 12:00 PM
tewee's Avatar
Default Re: AC on and rpms DROP...?
check your Idle Up Solenoid, which has 2 positions. closed when no additional air needed. open when additional air is needed (high idle).
seems like it fits your problem.
hope i didn't put u off track.
Old Apr 6, 2010 | 12:03 PM
hon-daddy's Avatar
Ill try anything, thank you for your imput.
Old Apr 6, 2010 | 09:14 PM
itr1244's Avatar
or try no a/c like mine
Old Apr 6, 2010 | 09:18 PM
hon-daddy's Avatar
i have to have ac.. to damn hot over here.
Old Apr 6, 2010 | 09:32 PM
PaulMc's Avatar
Painfully Stupid
The A/C just uses a lot of the car's power to work. If the idle decrease isn't too dramatic, it's normal as far as I know. My '01 ITR and plenty of other cars I've owned done the same thing. You'll probably experience the small loss of power when you're driving and put the A/C on 4 (full power). Another belt is rotating, more of the engine's power is being used for A/C at that, and it is normal for it to get to the point where you will notice/feel it.
Old Apr 6, 2010 | 09:43 PM
hon-daddy's Avatar
but my cars rpms go so low that you can feel the motor wanting to turn off.
Old Apr 6, 2010 | 09:56 PM
Serdar's Avatar
could be a problem with the compressor, I think it might need to be clean and lubed. I recommend bringing your car to an a/c shop and tell them to put new clean new refrigerant in your system.
Old Apr 6, 2010 | 10:03 PM
hon-daddy's Avatar
Yeah im going tomorrow, ill keep you'll updated. Thanks.
Old Apr 6, 2010 | 10:04 PM
Luchini's Avatar
Says in my Haynes manual that idle RPM is supposed to rise 50-100 RPM to compensate for the extra load the A/C places on the engine.
However it also says the idle should be 550RPM +/-50 RPM. Mine idles at 1200 RPM and with the A/C on it drops to 800 so I have a more normal idle with the A/C on which I dont understand
Old Apr 7, 2010 | 07:18 AM
wego5typer#431's Avatar
My Type r idles at about 7-800rpm when engine is good and warmed up. It only idles at 1100-1200rpm when I first start it up and engine is cold. 550rpm seems a tad low to me.
There is definetly something not right with hon-daddys Type-r. It should still have a smooth idle with the a/c on, and not struggle to stay running.
Old Apr 7, 2010 | 09:44 AM
score10's Avatar
hi i have a 2001 type r and have tried and replaced everything to try to get it to idle and not surge, i replaced, cap, rotor, iacv, plugs , wires, tps, cleaned intake manifold and tb, resest computer,changed fuel pump, fuel filter.... i even lowered the idle with the adjusment screw which seemed to help the most, i dont know what it could be...
Old Apr 7, 2010 | 10:01 AM
hon-daddy's Avatar
Ima try 2 more things you havent. Ima do a full service on my ac compressor and change the altenator.
Old Sep 28, 2018 | 12:26 PM
Orlando75's Avatar
Hi I know is 8 yrs later but I'm having same issues with my teggy,did you ever fixed the issue with the Idle when AC is on? If you did, can you please tell me what did you do to fix it?
Katastrophic
15
Jun 29, 2011 10:33 PM
JDM97R
Aug 7, 2004 11:59 AM
VTECRaZeR
Sep 26, 2003 04:35 AM
riceball777
Aug 18, 2003 10:11 AM
vietboixstunnah
Aug 7, 2003 12:41 PM
