Rear Tires burning out fast
Old Apr 5, 2010 | 11:23 PM
andrewchopstick's Avatar
Default Rear Tires burning out fast
For some reason ive gone through 3 different sets of rear tires in the past 5 months since i lowered it. I've gotten alignment twice at 2 different places. Could the reason my tires wearing out because of my coils or something loose?
Old Apr 6, 2010 | 04:18 AM
non-VTEC's Avatar
Default Re: Rear Tires burning out fast
what kind of car do you own? are the tires wearing out on the inside edges? how much negative camber does the rear have?
post up an alignment spec sheet if you have it.
Old Apr 6, 2010 | 02:52 PM
nsxtasy's Avatar
H-T Order of Merit
Something is definitely wrong. The most likely culprit would normally be the alignment (especially the toe). Other than that, have a close inspection done on your suspension. It could be anything - worn bushings, components that are bent, blown shocks, etc.
Old Apr 6, 2010 | 09:48 PM
r.wright's Avatar
where are you taking your car? is this like a big O tires/chain stores or is it an actual alignment specialty shop?
most chain shops will have specs for oem settings on their machines but real alignment shops should have the skill and expertise to align your vehicle and make adjustments according to your cars individual setup and/or diagnose what your issues may be.
Old Apr 7, 2010 | 07:38 AM
nsxtasy's Avatar
H-T Order of Merit
You might want to take it to an independent mechanic with a lot of suspension/alignment experience on our cars. I've heard very good things about this shop in your area.
Old Apr 7, 2010 | 06:15 PM
I've been too busy to look for the alignment sheet, ill try to get it up soon. Im only running -2 camber in the front and rears but the rears are wearing out like x10 faster. Another thing is when its raining and i run over reflectors on the ground, the rears seem to drift a little bit. The car gets pretty unstable going 65mph on the freeway when its windy and raining. I drive a 2004 Accord lowered on F2 coilovers.
3easy21
Jan 27, 2013 09:04 PM
craiger28
16
Apr 4, 2010 12:37 PM
djmeowmix Yes A Girl DJ
28
Jan 11, 2007 09:24 AM
tonezilla
May 1, 2006 03:57 PM
Kyles ej1
17
Sep 20, 2004 05:49 PM
