Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
thinking about switching my 07 v to 2wd turbo
Old Apr 5, 2010 | 06:35 PM
civicjason's Avatar
Default thinking about switching my 97 v to 2wd turbo
i bought my v about 2 months ago. I hate it being 4wd auto. It gets terrible gas milage and shifts like its gettting kicked in the sack(240k miles). i want to turbo it and i think i am going to remove all the 4wd and switch to a ls tranny all fwd and turbo. input please
Old Apr 5, 2010 | 08:57 PM
qwrty's Avatar
Default Re: thinking about switching my 07 v to 2wd turbo
07 crv?? k series engine?? how are gonna out a LS tranny
on it??
or
97 auto gen.1 crv?? from the miles that you put on it??
i would do supercharging it rather than turbo, i almost did
this to my auto crv.. (i have 3 Vs! LOL..) not much lag and
constant power in lower rpms....and JRSC made a specific
model for our Vs! or use LS and just buy the parts specific
for our V(belts/brackets..etc)..
as for 4wd system, (you could)
remove the prop shaft, its just 8 bolts holding it from both
ends.. i know several V owners did this and just put it back
on winter season...i think they save an average of 20-40%
of gas consumption... i did that on my auto V and had a similar
result....
HTH..
good luck!
Old Apr 6, 2010 | 07:56 AM
civicjason's Avatar
it is a 97, mistyped it. anywho.... I dont like superchargers, If i take the 4wd off i am going turbo all the way. I would use the exact same set up that i had in my ls eg. it got great gas milage and made great power.
Old Apr 6, 2010 | 09:10 AM
BJOnewiper's Avatar
Can you talk more about the process of converting from AWD to FWD? If it really is this easy, I'd consider it in exchange for the gas savings. It was be the same on a gen 1. 5 speed car?
Old Apr 6, 2010 | 02:33 PM
TTIWWOP's Avatar
Why would switching to a FWD tranny save 20-40% MPG? That makes no sense to me
Old Apr 6, 2010 | 04:00 PM
qwrty's Avatar
40% probably is ???? but theres several V owners who managed to
save 20% atleast when they removed the prop shaft, i kinda felt the
mileage too when i did it to my auto V, try visiting hondasuv.com and
crvownersclub.. i think theres several V owners who could enlighten
you up about this... some of my knowledge bout V came from those
sites... (oem specs/technical)
it might be caused by a lighter load on the engine coz instead of running
4wd at some time(when engaged) the engine is just powering 2wd...
this has been same issue or being talked about when i stumble on a
ford explorer pick up truck discussion....
HTH...
Old Apr 6, 2010 | 06:42 PM
TTIWWOP's Avatar
HTH...
I could understand this on an explorer or 4wd truck but the CRV only sends power to the rear wheels once in a plaid moon.. A PLAID MOON (that hardly ever happens) I just don't see how converting a 1st gen CRV from AWD to FWD would make any discernible difference in fuel consumption.
Old Apr 6, 2010 | 08:33 PM
qwrty's Avatar
all i remember is that in standard tranny Vs..1st gear is always on 4wd...
so that makes diff. in gas consumption right away, im not sure bout the auto
tranny.....??
for the 2wd option.. ill just remove the prop shaft rather than replacing the
tranny w/ the LS one...remember our Vs tranny gearing was made to suit what
our V needs...im not sure bout the ratio..all i could notice is that its good
on the mid range power and torque that our engine produce.. so its already
a match! this is just my .02c,
good luck on your decision!!!
keep us posted!
Old Jun 4, 2010 | 05:45 AM
civicjason's Avatar
Well it is now 2wd(fwd) i removed everything! the driveshaft, full rear diff and axles. SOOOO much better. Next im going to the 5speed and turbo will soon follow.
robitjcivic
18
May 28, 2008 03:58 PM
jdm_tnr
Jul 13, 2005 10:04 AM
CUSTOMCONNECTION
Jan 11, 2005 03:41 PM
LStech
Mar 12, 2003 07:38 AM
LSintegra
Apr 29, 2002 06:22 PM
