96 gsr suspension on a 91 crx si? HELP
ok basically i have a complete gsr suspension everything... now i want to swap the brakes all the way around on my crx i want to know what parts to use off what car to make it work and not have any issues. i also want to run the gsr front and rear sway bars is this possible and can i use the gsr master cylinder and brake booster. thanks
I'm pretty sure none of the parts you listed are compatible, except possibly the calipers and rotors but then you would probably need a different hub and caliper bracket.
I noticed you said you don't want to have any issues, if thats the case you should probably just sell all the gsr parts (save yourself the headache) and get what you can actually swap into your car.
look through the FAQS theres a lot of helpful information https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/88-91-crx-ef-civic-frequently-asked-questions-faqs-1508680/
basically what i want to know is can i swap the whole rear trailing arm without any problems and if i can i use all my stock crx stuff like rlca and compinsator arm and so on. ialso want to put the front gsr knuckle on my car is this ok to do without running into many issuses and if there is an issuse is theree anything i can do to fix it with any of the parts from eaither car.
And yes i did read the facts section to find my answers but no luck
I'm going to beat you with a stick for bumping your own thread over 4 hours in the deep morning, but after I going to eat my breakfast first then head to work before I deal with this.
Even worse, you're a Canadian! TO ARMS!
Until the militia wakes up, here is what you can use:
YES: Rear trailing arms including rear brake assembly
YES: Front brakes if you have EX Civic / DA Knuckles already, but if you do they are the same
NO: Front Spindles
NO: Anything that has any type of geometry to it in the front suspension
NO: Anything that has any type of geometry in the rear suspension
YES: I want a cookie.
NO: Front Spindles
thanks buddy that answered my questions.
p.s. i am all about peace and love not war and as far as i am concerened this is north america there is no difference between me and you
Nick998
19
Apr 6, 2011 05:21 PM
ImportRicer
Jan 30, 2005 09:52 PM
PartTimeRiceR
Jan 27, 2003 06:52 PM
