check engine
Old Apr 5, 2010 | 03:04 PM
honda data's Avatar
Default check engine
Well I have a 92 honda civic hatch. I have a b16 with gsr cams 44occ 50 trim honda data p28/. the check engine light comes on when im on full boost and begins to jerk in and out off boost? Does anybody knows how can I go about fixing this problem? And also having trouble with the v-tech activating at times?
Old Apr 5, 2010 | 03:09 PM
Ruben19's Avatar
Default Re: check engine
is the motor tuned?
how many pound of boost r u running?
Old Apr 6, 2010 | 07:40 AM
honda data's Avatar
The motor is tuned and im running 10 pounds?
Old Apr 9, 2010 | 12:30 PM
honda data's Avatar
Anything!
Old Apr 9, 2010 | 12:33 PM
98civdx's Avatar
Master Detailer
how much hp? how many psi of boost really doesnt mean much.
Is there any cels? Smoking? burning oil?
Old Apr 9, 2010 | 12:34 PM
98y8's Avatar
Check oil pressure?
Old Apr 9, 2010 | 12:51 PM
dpetro1's Avatar
you need to pull the code. if you have hondata s300 there is a tab that will show the code, if not jump the connector and pull the code the old fashion way.
maybe you are hitting a boost cut enabled by the tuner?
young geezer
May 25, 2016 08:39 PM
93ls10.0
May 31, 2015 10:45 PM
chriscool888
Dec 28, 2011 08:19 PM
zachsbat1
Apr 24, 2008 05:04 PM
g2_boosted
Dec 5, 2002 05:20 PM
