d16z6 idle is low
Old Apr 5, 2010 | 10:14 AM
jdmsir4dr's Avatar
Default d16z6 idle is low
ok when i start up my car it idle high and then when it warms up the idle drop excatly half way below 1 for couple of second and then its drops more just a lil bit above the first line on the rpms.. the car feels like its gonna stall even do its juts parked there.... i changed the fuel filter,put oem spark plugs, put lucas fuel injector cleaner,cleaned the iacv also tryed to adjust the screw on the tb according to the haynes manual and still nothing ...oh by the way my check engine is on could dat be part of the problem.. any help plz
Old Apr 5, 2010 | 10:18 AM
Black Diamond's Avatar
Default Re: d16z6 idle is low
My 94 does the same thing i dont have any problems, but im in for a solution also..
TTT we go!!
Old Apr 5, 2010 | 10:28 AM
jdmsir4dr's Avatar
i forgot to add dat my vtec is not wired up cuz the harness is not for vtec
Old Apr 5, 2010 | 10:31 AM
That could be your problem i would try to track down a vtec harness!
Old Apr 5, 2010 | 10:33 AM
EracerUgone's Avatar
If ur vtec wire is not connected that might give u the CEL but ur idle not really sure
Old Apr 5, 2010 | 10:37 AM
hamase161820's Avatar
try running the vtec wiring first..plug in the proper ecu. cuz the cel light is most likely on cuz of the vtec..that can add to your idle problem..as well as timing and a few other things..if the first steps dont help you may have bad rings.
Old Apr 5, 2010 | 03:06 PM
Dmiesterpr18's Avatar
TRIAL USER
i have a d16z6 and ive tried to time it and it wnt start.. i brought it to tdc and marked the crank by the single line above the other 3 on the pulley.. can someone plz help to properly time my car properly by step one.. thanx alot guys and girls
Old Apr 5, 2010 | 05:55 PM
jdmsir4dr's Avatar
it has a p28 ama have to try to wire it up directly to the ecu like my boy did...but a while back i tried to put 2 different ecu and both burned it idk why ....u could of see smoke coming out of both ecu..but wat i find weird is dat the p28 dats on right now it not burned so idk y wen i change it for another p28 it did that
Old Apr 5, 2010 | 08:58 PM
weatherall123's Avatar
We need a definitive solution!
Old Apr 5, 2010 | 09:31 PM
Former User's Avatar
The first step is to pull the CEL codes and post them.
Old Apr 6, 2010 | 05:40 AM
jdmsir4dr's Avatar
were can i find the d.i.y step to check the cel i cant find it on here
Old Apr 6, 2010 | 06:23 AM
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Old Apr 6, 2010 | 09:08 AM
gil_Type R's Avatar
I have the same idling problem, in for the solution! Check your vacuum lines, it probably has a leak. It's probably that, or a bad gasket on your intake manifold or exhaust manifold. I just ordered all my gaskets to replace them. I also cleaned my idler air control valve. Gotta check my vacuum lines when I get some time off.
Old Apr 6, 2010 | 10:15 AM
jdmsir4dr's Avatar
so i checked my cel .. and it gave me (21 VTEC spool solenoid valve) so im assuming dat means dat the vtec it not wired up.. so im wondering how do i wire up the vtec directly to the ecu ..cuz i dont wanna have to get a vtec harness lol
Old Apr 6, 2010 | 12:08 PM
HondaPartsHero's Avatar
Technical Hero
do you have the VTEC pressure switch wired up as well? What model civic is this in DX, LX. etc?
Old Apr 6, 2010 | 04:07 PM
jdmsir4dr's Avatar
i have a 95lx with a d16z6
Bj Le Det
Jan 6, 2017 12:06 AM
JDM-EJ1
Oct 1, 2004 08:12 PM
Mr_CRX
Sep 29, 2004 12:01 PM
