need help when i turn or make a u turn something make a nosie?? tire rubbing?
when i make a turn or a u turn something makes a noise?? it cant be the tire rubbing because i still have a two finger gap. i got tein type flex. what can it be???
and it make the noise only the front. HELP????????
what size are u rims width wise? and the offset? maybe when ur turning the wheel all the way to one side where it locks, it could be rubbing the inner wheel well...take off ur rim and see if any rubbing is on the insied of the wheel well.
or could it be ur teins squeeking or something?
[Modified by KiddEng, 11:36 PM 9/9/2002]
If it is clicking then its possibly the cv boots.
If it aint the tires, it's the CV's...
how much is the cv boot? my hatch is a 95 cx with about 67k and i got stock 95 gsr rims. any more help?
It should me around 100 or so to have it fixed, or you can take it apart yourself and the boot is about 20-30 I think. Or you can just replace the axle you can get them for 70 and put it in yourself.
Keith
Keith
Actually if it's already clicking then replacing just the CV boot won't help.
That means the CV boot has been torn long enough to have slung most of the grease out of the joint and dirt has gotten in it as well.
You just need to buy a whole new axle. Go to any local parts store and buy one with a lifetime warranty for like $80.00 or so after they credit you for bringing your old one to them as a core.
If you need a tutorial on how to change an axle I wrote one up a while back - I can find it if need be.
Describe the noise. Is it a clicking? Rubbing sound? You need to be more descripitive when trying to solve such problems. It helps us help you.
my car also does this, its a 95 cx with stock suspension and i hear clicking noises when i drive and turn, i have a jdm b16 sirII as a motor, so what kind of axles should i get to replace them?
As far as axles go, you can order them for any of the following:
1993-1997 Del /sol VTEC
1994-2001 Integra - all models
1999-2000 Civic Si
If they have the non-ABS ones for cheaper, then get those. If they only have an ABS one, then that's okay too. All ABS axles differ in is a little ring around the edge for the ABS sensor.
The axle place doesn't care that you have swap. they want to know what car you're working on, so try all of those listed above. Sometimes it confuses them when you ask about car after car, but simply tell them that even if their part numbers don't cross reference that you can use any of those axles.
1999-2000 Civic Si
its a clicking sound. and yes can you make a step by step on how to change the axle by my slef.
1999-2000 Civic Si
1999-2000 Civic Si
I had a right CV boot replaced on my Civic for $69. That included parts and labor. Good thing you caught it or it would have been f*cked up later on.
What if he aint got a swap? He probably needs the d series axles.
