intake mani
Old Apr 4, 2010 | 07:44 PM
slo2k's Avatar
Default intake mani
i am swapping from a f22b2 head to a f22a1 head. i need to know what intake manifold will bolt right up.
Old Apr 4, 2010 | 08:13 PM
Andryzzle's Avatar
Default Re: intake mani
besides the obvious f22a mani, evolution industries makes an adapter to fit an H22 mani on there. Also I believe the h23 non vtec manifold goes on there without *too* much fuss. check cb7 tuner, that engine would be their bread and butter.
edit, didn't you ask this before?
Originally Posted by TouringAccord
for the intake manifold... use one from either a H23A1 or a F22A6, since you are going turbo though, you'll want the larger plenum of the H23A1.
Old Apr 4, 2010 | 09:33 PM
slo2k's Avatar
probably can't remember. figured it would be easier to just ask again.
this is a boosted car also.
Old Apr 4, 2010 | 09:55 PM
GhostAccord's Avatar
https://honda-tech.com/forums/honda-accord-1990-2002-2/heads-2736877/
H23 upper plenum w/F22A6 lower.
Old Apr 5, 2010 | 07:42 AM
Andryzzle's Avatar
That works? Is it a simple bolt on? What are the advantages over a full h23 manifold?
Originally Posted by Evolution Industries
If you have an F-series motor and want to gain 20-30 horsepower and gain 5-10 more torque without changing internal parts in the motor, Evolution Industries designed an adaptorplate to mount on a stock H22 manifold to the F-series head. A stock 1993 Honda Accord with a F22a motor was used to test the adaptorplate. Baseline pass showed 80.2hp and 117.4lbft at 6364rpm. After installing the adaptorplate with the H22 manifold it made 112.7hp and 130.0lbft at 6364rpm. So a gain of 32.4hp and 12.6lbft.
http://www.evoindusa.com/
Old Apr 5, 2010 | 08:03 AM
With the F22A6 bottom half there is no modification/fabrication required. It is a direct bolt on. The H23 bottom-2-F22A head requires some fab work IIRC.
Old Apr 5, 2010 | 08:18 AM
hondamark35's Avatar
i wouldn't call it fab work... all you really need to do is gasket match the runners/ports and bolt it up. i'm no H-series expert though so i may have the "one" that works easily. i'm working with an OBD-1 H23 manifold and an F22A4 head.
Old Apr 5, 2010 | 08:52 AM
It must be the runner length on the A6 that everyone is looking for. I have never done the swap myself. I have seen quite a few builds using the H23 plenum and throttle body with the A6 runners. That being said, they are on mostly N/A setups. Maybe it won't matter as much with a boosted application.
Old Apr 5, 2010 | 07:26 PM
slo2k's Avatar
if useing the h23 mani. does the f-series waterpump tube work with the h-series. also the thermostat housing. i have found a few build ups that use this and that mani's. some just don't have little detailed info.
i have the a1 intake mani that came on the head. the plenum just looks a little small.
Old Apr 6, 2010 | 03:21 AM
yeah, the F22A thermostat housing works with the H23 manifold. i think i'm using an F22A "metal pipe" as well.
Old Apr 6, 2010 | 04:10 AM
nus_dogg's Avatar
x2!
Old Apr 6, 2010 | 06:26 PM
slo2k's Avatar
are the a6 runners longer or shorter than the h23.
Old Jun 9, 2011 | 07:30 PM
project_cb7's Avatar
i was passing by the forums and droppin to this post.funny you mentioned the evloution project they did with the throttle body plate adaptor.my vehicle was the one they tested it on(or one of the cars they tested if more then one).im running a f22a1,and the 97gen. prelude dohc intake manifold with the adaptor plate.i feel the diff.
Old Jun 9, 2011 | 07:41 PM
nus_dogg's Avatar
Nice, but this thread is a little over a year old.
Old Jun 9, 2011 | 09:02 PM
yea sorry.but im bored/new to h-t and just thought id add my 2cents.
breakyadown_89
May 2, 2009 11:15 AM
fastazzf22
Jul 15, 2007 02:23 PM
deeweezy187
Dec 12, 2005 04:15 AM
flip1199
Jun 5, 2004 07:29 PM
initial-d
Nov 26, 2001 09:01 AM
