valves, valve springs + retainers
Skunk 2
http://www.skunk2.com
the advantages of these are less wear and tear, allowing your engine to rev quicker and higher.
I have crower with no complaints, I am using CTR cams with stock valves crower springs and retainers. I accidentally reved to 9948 with no harsh side effects. crower
El Veterano de Sur Califas
Skunk 2
It will let you rev higher, but u dont need it, unless u have a bigger cams. And as the advantages.....Valves=Are made stronger, some can raise compression a bit, and some are coated, and might be lighter(not needed in ur case IMO) springs= lets u rev higher(no needed if u have stock cams) Reatiners= they are made of titanium, and will not break(i would get these
) hope this helps.manny
Guest
Posts: n/a
Less wear and tear?? Rev Quicker?? Sorry, but that's not true. Actaully if you put aftermarket springs it will put more wear and tear on your cams. And it wont let u rev quiker
) hope this helps.
manny
1990hondacrx
13
Apr 6, 2009 08:31 PM
rorik
28
Dec 25, 2007 12:44 PM
ty91184
Oct 10, 2007 05:33 PM
T--Rex
11
Jul 27, 2004 03:36 PM
CRXSleeper
Sep 9, 2002 10:47 PM
