Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2003 V6 Accord - Timing belt question(s)???
Old Apr 4, 2010 | 01:11 PM
bb62's Avatar
TRIAL USER
Default 2003 V6 Accord - Timing belt question(s)???
My inlaw has a 2003 honda Accord with about 105,000 miles. She has been told by her dealership that the timing belt NEEDS to be changed as a part of routine maintenence. My questions:
1. Does the belt really need to be changed at this point? If not, then when?
2. Does the Honda V6 have free-wheeling pistons that would prevent an internal castastrophy if the belt breaks?
3. What would a job like this, if necessary, cost?
4. Is this a do it yourself kind of job? If so, what hardware woyuld be required to get the job done?
Old Apr 4, 2010 | 02:07 PM
BLKFLSH's Avatar
Default Re: 2003 V6 Accord - Timing belt question(s)???
1. Yes, it should be changed as soon as possible
2. No, if the timing belt breaks, you risk damage to internal engine parts (valves, pistons, cylinder walls).
3. It will cost anywhere from $500 to $1000 or more, depends where you have it done, and what parts they change (besides the belt, like water pump, tensioner, seals, etc.)
4. It's a DIY job for someone with a good shop manual, and some mechanical knowledge. I would not recommend someone with no experience working on engines try this. There are how-to's on the Internet (google is your friend), if you would like to get an idea what is involved. Here is one for an Acura TL, which is very similar. Have a ball.
Old Apr 4, 2010 | 02:44 PM
KWayRacing's Avatar
^ couldn't be anymore precise of an answer.
Old Apr 6, 2010 | 06:51 PM
mixjuan's Avatar
Anyone know how easy it is to replace an O2 sensor on the '03 Accord V6 Coupe? It is the one before the catalytic converter.
Old Apr 6, 2010 | 08:54 PM
PowerUser's Avatar
Two things to keep in mind here or any forum.
-First and foremost, use the forum's "Search" before tring to start a new thread.
-Secound, if the search didn't work, don't hijack other people's threads that don't relate to the question you're trying to ask. I'd ratheir see you start a new thread
This should help get you started:
https://honda-tech.com/search.php
Old Apr 7, 2010 | 05:29 AM
mixjuan's Avatar
my apologies. I did search the site and found nothing relating to the V6 Accords.
secondly, as I am new here, I am not allowed to start a new thread for 15 days, and at that not until after I have made 5 posts. This is why I went to a question relating to a 2003 V6 Accord.
Old Apr 7, 2010 | 04:17 PM
Ross 2.0's Avatar
In a Junkyard near you.
That Accord has 4 sensors. Make sure you're talking about the right one.
shrekfiona
17
May 31, 2013 11:04 PM
Two400
Jan 22, 2008 04:10 PM
Goofyboy
Oct 19, 2004 06:25 PM
e_r_i_c_
Apr 22, 2003 07:02 PM
