car running rich.
Old Apr 4, 2010 | 12:30 AM
twotonecivic's Avatar
Default car running rich. Code 43
i'm also having a little problem w/ it running rich. I've found a few vacuum leaks that need to be fixed. Can I just tie into any vacuum hose. One of the sensors is broke and the vacuum port has just been plugged so when I hook up the new sensor I'll have to run a vacuum hose to it. The map sensor o-ring was missing so i replaced it and the car wouldn't start. I took it back out and it started. I just got the car so I'm taking care of someone else's mess. it's a 94 lx 4door w/ a z6 swap. Runnin off a p06 right now so no vtecage. Any input would be helpful.
Old Apr 4, 2010 | 08:15 AM
Default Re: car running rich.
it's throwing a code 43 which says fuel supply system. code 10 iat. code 17 vss. any ideas. would the iat throw off the fuel system?
Old Apr 4, 2010 | 09:56 AM
car still won't start..... i unplugged the ecu and plugged it back in. now it won't start and i have no cel codes.
jbiel
11
Jan 11, 2009 06:27 AM
Preferio
Jul 6, 2005 08:56 AM
t . b o z
Jan 2, 2005 12:58 PM
Sohc Driver
Sep 21, 2003 11:05 AM
